Thread: Smooth my ride
Results 1 to 11 of 11
  1. #1 Smooth my ride
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I am trying to make my daily commute as smooth as possible .
    Here is what I have done so far : new tires, alignment, front tie rods, rear struts (complete assemblies), Moog rear end links.
    I am thinking front strut assemblies will give me the best improvement. Ball joints ? Sway Bar ? Any suggestions ?
    1997 Red GTP 182000 miles stock
  2. #2 Re: Smooth my ride
    Dec 2012
    Where 4T65E's were born
    That's a good amount of things to get the best out of the car, although front sway bar links will make a large difference in handling while turning. Still do the front struts. If you get a new sway bar, it may be an improvement also because Dorman's bar is thicker, and solid comparing to the stock one being thinner and hollow. Definitely use moog front end links instead of the Dorman's that come with the bar if you do decide to change it. Moog links up front alone will make a large difference is they're still oem.
    I can't think of anything else right now, but changing the lower control arms/ball joints as an assembly may help a bit more if the bushings are worn out, but it's not really worth the price of new ones and another alignment for what it will help. Unless you have clunking, it will solve that if you still have it after changing the sway bar links.
    Sold.
  3. #3 Re: Smooth my ride
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    The other thing to think about is hub assemblies if you're getting a vibration from up front.
    +1 on the Moog front end links. Quick, easy, and cheap, and makes a HUGE difference in handling.
    If you're getting a bounce, the strut assemblies would definitely be a huge improvement. LCAs won't do much for you unless you're getting a clunk, like was said before.
  4. #4 Re: Smooth my ride
    Eh, I'd beg to differ on the LCA's.
    They'd make a pretty big impact if his current ones are shot.
    Rock Auto sells complete ones as well.
  5. #5 Re: Smooth my ride
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Forgot to mentions, the front hubs were just done also. No clunking , just road feel is not as smooth as I would like.
    F**K , I must be getting soft in my old age , LOL.
  6. #6 Re: Smooth my ride
    Donating User Odi's Avatar
    Chicago South Suburbs
    175k miles, whadya expect? they weren't the comfiest cars to begin with.
  7. #7 Re: Smooth my ride
    GTP Level Member
    Oct 2011
    Raleigh, NC
    You are right Odi. Just trying to improve. Also trying to determine the best tire pressure for the best ride vs. tire life.
  8. #8 Re: Smooth my ride
    Dec 2012
    The sticker says 30 psi, but I'll always put in 32-35 since I'd rather have longer tire life. So use 30 and see how you like it, what are they at now?
    Sold.
  9. #9 Re: Smooth my ride
    GTP Level Member
    Oct 2011
    Raleigh, NC
    33 cold, i will try 30 . Just worried about tread wear.
  10. #10 Re: Smooth my ride
    Dec 2012
    30 will be fine, it's the recommended pressure from the factory for our cars.
    Sold.
  11. #11 Re: Smooth my ride
    i always felt 30psi was too low. i like my michelins at ~35psi.
  1. Smooth out maf cells
    By DoubleBlown in forum PCM Tuning
    Last Post: 02-21-2012, 10:09 AM
  2. Smooth Valve Covers
    By stlmo_gtp in forum How To Write-Ups/Tech Tips
    Last Post: 01-19-2012, 02:03 PM
  3. smooth
    By f3racer in forum Off Topic Discussion
    Last Post: 10-11-2011, 10:10 PM
  4. Paint not smooth...help
    By joeringo11 in forum Visual/Body Modifications
    Last Post: 07-15-2011, 12:46 AM
