Thread: Front GXP brake upgrade which hoses?
Results 1 to 11 of 11
  1. #1 Front GXP brake upgrade which hoses?
    Aug 2013
    Goshen, Ohio
    I am doing a brake upgrade to the front of my 99 GTP. I have new rotors and pads and a nice set of used calipers and brackets. Which hoses do I need? I assume that at some point even the front brake lines changed to metric. I have a mastercool flaring kit so if I need to change the ends on the stock lines no problem. I also have the banjo bolts for the dual piston calipers. I searched GXP brakes in this section and got 0 results. Go figure?
  2. #2 Re: Front GXP brake upgrade which hoses?
    Jun 2011
  3. #3 Re: Front GXP brake upgrade which hoses?
    St. Louis
    Hopefully you have 17" rims on there to clear the GXP brakes. But yea, read away.
  4. #4 Re: Front GXP brake upgrade which hoses?
    Aug 2013
    Goshen, Ohio
    Quote Originally Posted by FordMan77 View Post
    Yes, I have Comp G wheels, and I test fit them tonight. They have plenty of clearance. I looked at the brake thread i guess I missed it.
  5. #5 Re: Front GXP brake upgrade which hoses?
    Aug 2013
    Goshen, Ohio
    So basically, the answer is buy stainless lines. So I have this kitUniversal Hydraulic Flaring Kit NOT FOR STAINLESS to do the lines if need be. I ordered new stock lines for now. They were less than $50. Something else I noticed is that the rear LH check valve before the caliper is weeping. Do people delete those or should I go to pull and pay and get a new one?
  6. #6 Re: Front GXP brake upgrade which hoses?
    Arizona
    Quote Originally Posted by Bowtie70SS View Post
    All you need is Zzp braided hoses there all the same patterns just bolt on and go
    Edit and FYI when I did the swap on my GTP I used a piece of4-5 inch brake line that threaded into the portion against the wheel wheel an made a u shape that way you have all the length you could ever need. If you need pics I'll try to dig some up. Its universal brake line they have in the back just bring your brake hose with you to get that thread pitch
  7. #7 Re: Front GXP brake upgrade which hoses?
    Aug 2013
    Goshen, Ohio
    I don't mind buying the brake hoses. I will look at rock auto for the specs on the inlet line size and compare them to stock. Good idea about the piece of line though.
  8. #8 Re: Front GXP brake upgrade which hoses?
    I had to use the GXP oem lines on my 2004 when I swapped. I had ZZP lines from many years ago and the fronts were not long enough, since the banjo fitting location is lower on GXP caliper.
  9. #9 Re: Front GXP brake upgrade which hoses?
    Arizona
    To clarify I'm reffering to Zzp extended lines on their website
  10. #10 Re: Front GXP brake upgrade which hoses?
    Jun 2011
    I dont know about GXPs, but my stock lines worked for my C5s.
    lol i dont think this post was very helpful in your situation... lol
  11. #11 Re: Front GXP brake upgrade which hoses?
    Aug 2013
    Goshen, Ohio
    So....I came home from work tonight and did the GXP brake conversion including changing one of my hub assemblies in about a hour and fifteen minutes. Very easy conversion and I used a new pair of GXP brake hoses to complete the swap. I bent the hose brackets down a little but the hoses bolted up perfectly to the lines and brackets. I used the stock GXP banjo bolt. All I can say is WOW this car stops like 900% better. I just sold a 04 CTS-V and it had incredible brakes now the GTP is at least in the same time zone.newbrakes.jpg
  1. Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    By mikes01gtp in forum Brakes/Suspension/Chassis
    Last Post: 04-15-2013, 09:12 PM
  2. F-Body front brake upgrade
    By jlgp2007nc in forum General Grand Prix Discussion
    Last Post: 03-26-2013, 09:26 PM
  3. My 12" front brake upgrade. COMPLETE. Pics
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2010, 06:58 AM
  4. 12" front brake upgrade rim compatibility?
    Last Post: 05-06-2010, 08:22 PM
  5. Stainless brake hoses
    By LEAD LAP in forum Brakes/Suspension/Chassis
    Last Post: 03-14-2009, 03:23 PM
