Thread: Rear brake rotor question.....
Results 1 to 9 of 9
  1. #1 Rear brake rotor question.....
    Nov 2012
    Lebanon, Ohio
    I have a 2007 GP base model that has solid rotors. I wanted to know if switching to a vented rotor would work?
  2. #2 Re: Rear brake rotor question.....
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    yeah it will
    http://www.grandprixforums.net/big-b...ead-39174.html
    ^ more indepth info in here.
    may i ask why tho?
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  3. #3 Re: Rear brake rotor question.....
    You could switch, but you'd gain nothing from it. Would be just spending more money.
  4. #4 Re: Rear brake rotor question.....
    Nov 2012
    Lebanon, Ohio
    Well they are the same price I just need new rotors and it is an option. Just wondered.
  5. #5 Re: Rear brake rotor question.....
    Its not just a simple upgrade of switching rotors, so the cost is not the same.
    You need the other hardware components to make it work.
  6. #6 Re: Rear brake rotor question.....
    Nov 2012
    Lebanon, Ohio
    Lol for change from solid to vented worked out fine I'm all done they were identical diameter and the thickness wasn't that much different paid the same price.
  7. #7 Re: Rear brake rotor question.....
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Quote Originally Posted by Spike89 View Post
    Really? I'd like to see a pic of those vented rotors.... the stock rear rotors are solid and if memory serves me correctly less than 1/2 inch thick....
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  8. #8 Re: Rear brake rotor question.....
    Nov 2010
    Maryville, MO
    i too am curious, are those rotors made by a company to replace your stock ones?
    // 2005 Comp G
  9. #9 Re: Rear brake rotor question.....
    Jul 2013
    IL
    I think, that would make me worry about the safty factor.
  1. Brake Rotor Ideas
    By develand in forum Brakes/Suspension/Chassis
    Last Post: 04-12-2012, 04:57 AM
  2. rear brake question
    By 04BlackComp_G in forum Brakes/Suspension/Chassis
    Last Post: 08-02-2011, 10:25 PM
  3. Brake Rotor Question
    By SNeitzel in forum General Tech Discussion
    Last Post: 10-01-2010, 12:21 PM
  4. brake rotor.
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 09-24-2009, 02:32 PM
  5. Rear brake upgrade question
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 09-16-2009, 03:15 AM
