Thread: Poly sway bar bushings
Results 1 to 9 of 9
  1. #1 Poly sway bar bushings
    SE Level Member rhenuset's Avatar
    winnipeg
    I want to upgrade my bushings from junk rubber to some poly.
    I checked out Energy Suspension Parts Dealer, Specializing in Energy Suspension Bushings Suspension Components. and I came up with this
    Front bar - 191130 Prothane Universal Sway Bar Bushings - 3/4 Inch - B
    Rear bar - 9.5122_Rear Energy Suspension Rear Sway Bar Bushings - 18mm
    I have a 20mm front bar and the only thing close enough that was non greasable was the 3/4" bushing.
    I have an 06 gt btw. If anyone has done this before (Im sure you have) what parts did you use and what not else?
    Thanks
  2. #2 Re: Poly sway bar bushings
    I'm pretty sure people just go with a MOOG link when they want to upgrade.
  3. #3 Re: Poly sway bar bushings
    winnipeg
    No these are actual bar bushings not end links. I have already done moog end links front and rear. My end links connect to the strut so I cant get poly links.
    Its easy to find bushings for the 97-03 gps but mine 04+ so I want to know if anyone has done this
  4. #4 Re: Poly sway bar bushings
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    I've been researching this some too and plan on going with the energy suspension bushings. From what I can tell as long as you have the right diameter they will work with your bar.
    If you were looking for a 20mm one I found this. All i did was google energy suspension 20mm bushing.
    Energy Suspension 9.5124R 20mm Stabilizer Bushing : Amazon.com : Automotive
  5. #5 Re: Poly sway bar bushings
    Jul 2013
    Cranston, RI 02921
    I just did one this past weekend on my 2003. The stock bracket had snapped off. My 2003 has a 33mm bar, but I used a 31mm because the local parts store had it in stock.
    Few things to consider:
    1) Jack the car up in the middle, not on the side. This will remove tension from the bar. Be safe and use jack stands.
    2) Be careful you do not snap the bolts taking the old one off. Think about how ugly it would be to snap a bolt off in the hole. Use some penetrating oil and work it back and forth to loosen the grim and rust on the bolt. When you reinstall, torque it down correctly. I used anti-seize on my threads in case it needs to be serviced again.
    3) The energy star bracket I used was a universal fit with a bolt slot rather than single hole so the bracket will work in many cars. The bracket comes with some pretty small washers. I placed some larger diameter washers to cover the slot and make it more rigid.
    4) Follow the instructions and grease it before you put it on.
    Good luck
  6. #6 Re: Poly sway bar bushings
    winnipeg
    Quote Originally Posted by SomeDudeAtHome View Post
    The diameter works but for the front the bracket bolts are more than 2 7/8" apart and you cant use the stock bracket with these poly bushings, I have tried. You will need the bracket with the max spacing at 3 5/8". Thats the only problem, nothing with the 3 5/8" spacing comes in a 20mm. I would rather use a smaller bushing than larger. kinda obvious tho
    3/4" is the closest I can find with the right bracket
  7. #7 Re: Poly sway bar bushings
    winnipeg
    I founD these bushings
    W0404-20 Whiteline Front Sway Bar Bushings - 20mm
    they should work for front
  8. #8 Re: Poly sway bar bushings
    Buffalo, NY
    Amazon.com: Energy Suspension 9.5157G 13/16" Greasable Sway Bar Set: Automotive
    What about those. According to the energy suspension website they're 20.5mm and the largest spacing they have.
  9. #9 Re: Poly sway bar bushings
    winnipeg
    Im not sure if the 20.5mm would be a tight enough fit. I ordered a 19mm (on accident) for my rear 18mm bar and it was loose. That bushing however is only .5mm bigger so who know maybe that .5 would work. I ges the only way of knowing if that one will fit is if someone contacts the manufacturer.
  1. Poly dogbone bushings
    By 99grandprixman in forum General Grand Prix Discussion
    Last Post: 01-19-2013, 01:13 PM
  2. Poly control arm bushings??
    By Swiggles in forum Brakes/Suspension/Chassis
    Last Post: 03-22-2012, 07:38 PM
  3. Poly sway bar bushings for GMPP handling kit
    By crbquist in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2011, 11:57 AM
  4. Poly Sway Bar Bushings
    By 2000SILVERSE3800 in forum Brakes/Suspension/Chassis
    Last Post: 05-01-2011, 04:20 AM
  5. need LCA's/bushings but want poly bushings...
    By Regalgs98 in forum Brakes/Suspension/Chassis
    Last Post: 01-14-2011, 09:24 PM
