Does anyone know if this tool will work to decompress the piston on the rear disc brakes of an '06?
It'll work but it sucks
is that thing!?! I always use a large hand twist C-clamp to decompress my pistons and on any other car i work on
the 04+ rears twist in, you will brake them doing the old c clamp action, needle nose pliers is what i use
Hmmmm I haven't taken a rear apart but I have changed the pads and it still worked fine
Yup rears twist. Fronts on the other hand use the old fashion c clamp method. That tool does work.
INTERESTING. learned something new. are the pistons actually groved or what makes them twist?
I believe gxp's push in.
i seem to think the same way because theyve always just pushed in when i push them. dont quote me though i need new rear brakes and rotors now cause their worn badly so i will definately look closer when i do them
The 04+ twist in because of the parking brake is built into the rear caliper.
Marines has a Gxp. His rear calipers push in since the parking brake is not in the caliper.
All other 04+ rear calipers need twisted in. And as said before, don't waste 10 bucks on that little tool. A pair of needle nose do the job fine.
