New to site. I did do a search, but it looks like everyone is looking for slotted and drilled rotors.
I did look around a lot on the internet, and it seems like slotted and drilled are for looks and only good for cutting weight. Here's the top negative information I found:
-Lose braking surface area
-Stress cracks on drills and slotts
-There is no proof that they are effective
With that said; I am looking for BLANK brake rotors for a '99 GTP. I found Brimbo front brakes, but no rears. I do not know anything about brake rotors, so any help will be useful. I am probably going to get HAWK brake pads. Could someone give me their two cents on what model to get for daily driver, but aggressive. I was reading ceramic isn't worth it because they need a lot of heat to be effective?
Lastly, I read the thread on upgrading to a 12' rotor in the front. Has anyone done this? Is it worth it?
I understand that you can't believe everything you read online, so my information can be wrong. If you are going to contradict what I said above, please provide support. Thanks for your help in advance
