Thread: Dorman Subframe Bushing any good?
Results 1 to 2 of 2
  1. #1 Dorman Subframe Bushing any good?
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    '03 GTP 135K mi. I'm about ready to take on my next repair. I've convinced myself I am cable of dropping the subframe and am going to replace the bushings. I haven't had much luck finding options for parts. gmpartsgiant has them, about $75 each front, and $60 each rear. I also found this: DORMAN Part # 924006, for about $30 at rockauto. However, the Dorman part doesn't seem to match GM part numbers and Dorman does not say if it is for front or rear (it looks like front to me????) Has anyone used the Dorman part? Know for CERTAIN if its front or rear? Recommend using or stay away? Thanks in advance to those in-the-know,w/ experience and that share knowledge and experiences!
    The problem that's causing the issue is right there between the seat and steering wheel. It's you
  2. #2 Re: Dorman Subframe Bushing any good?
    Jan 2012
    FT Campbell, KY
    Dorman is a VERY good brand, I've had nothing but GREAT luck with them. Iirc, they're a sub-company of Federal-Mogul, who are like the single "best-est" out there. I'd try to stay away from anything grease-able and go for solid rubber or polyurethane for pure longevity. "Ohh, but, see...that's a problem...I don't want the horrid vibration and rumble that poly gives off and rubber's very soft..." Not really the case at all. Solid rubber does give a lot less than hydraulic mounts or OE mounts, but there's no real vibration or rumble. The poly stuff that I have in my RWD L36 does transmit quite a bit of vibration through the chassis and body, but it's not very intrusive at all.
    To answer your initial question, though: Dorman is the s*!!!
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  1. Dorman parts any good?
    By apierce1289 in forum General Grand Prix Discussion
    Last Post: 10-04-2021, 06:40 AM
  2. Question about Dorman 970-042
    By stealthee in forum General W body
    Last Post: 05-22-2012, 09:43 PM
  3. Dorman vs. GMPP swaybar?
    By Mjcanton in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2011, 10:50 PM
  4. Dorman Intake
    By GMFI in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2009, 01:11 AM
  5. how to check the bushing on stall converter if good/bad?
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-11-2008, 05:36 PM
