Thread: Squeaky noise from front passenger wheel...
Results 1 to 7 of 7
  1. #1 Squeaky noise from front passenger wheel...
    May 2013
    Midland
    having some issues with a weird squeaking noise that i can't get to the bottom of. Everytime i make a hard left turn through a parking lot I get a squeal almost like a brake sound when they're wore out or something.. idk, changed the pads to hawk performance and got new rotors and didn't seem to effect anything. Awesome breaking power though!!! I'm glad the hubby convinced me on getting these things. I can stop on a dime now
  2. #2 Re: Squeaky noise from front passenger wheel...
    I wonder if the backing plate/dust plate is rubbing on the rotor.
  3. #3 Re: Squeaky noise from front passenger wheel...
    May 2013
    Midland
    Someone suggested maybe something in the boot or something along that line? It only happens on the passenger side and just today it started doing it on hard right turns as well as left. It happens about once every wheel rotation.
  4. #4 Re: Squeaky noise from front passenger wheel...
    SE Level Member OldFart's Avatar
    Sep 2011
    Ontario, Canada
    Wheel bearing?
    Stock 2001 GTP
  5. #5 Re: Squeaky noise from front passenger wheel...
    Mar 2013
    Tionesta Pa.
    I just had the same problem and mine was the control arm had routed and cracked pretty good where the sway bar links attach.
  6. #6 Re: Squeaky noise from front passenger wheel...
    May 2013
    Midland
    Actually believe it or not, it has gone away ever since I had my front tires rotated. I'm pretty sure it is just a coincidence but maybe something was too tight...
  7. #7 Re: Squeaky noise from front passenger wheel...
    Arizona
    It was your dust shield when the took off the tire they probably hit the rotor back on it and knocked it back and I hope you rotated your tires left and right and not front to back
  1. Front wheel noise
    By Skip77j in forum General Tech Discussion
    Last Post: 04-06-2013, 08:49 PM
  2. Knocking Noise in Front Wheel
    By gamefreak in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2013, 07:22 PM
  3. Front passenger wheel help
    By DirtDog in forum General Tech Discussion
    Last Post: 09-09-2012, 03:14 PM
  4. Strange noise from front wheel
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-09-2009, 05:43 PM
