Thread: Rear Brake Hose Oddity
Results 1 to 3 of 3
  1. #1 Rear Brake Hose Oddity
    May 2013
    MN
    I am new to the forum and I have a question regarding brake hoses. I just replaced the caliper on my 04 Grand Prix GT and decided to replace the hose as well. I found out that none of the hoses available at the local parts store or the dealership match what I have on my car. All the parts I found had a 90 degree bend out of the banjo fitting as if the banjo attached to the ends or the back of the caliper. The hose I broke off has a banjo with a piece of tube for about 3-4" with very slight bend to it to clear the parking brake assembly. The car is out of commission until I find the proper brake hose that will allow me to reinstall the wheel. I tried utilizing the parts supplied by the parts store but had I installed it fully the hose would have had a kink in it.
    Has anyone had this issue before or does my car have the only straight banjo fitting on the drivers side rear?
  2. #2 Re: Rear Brake Hose Oddity
    Pic? and pic of installed parts?
  3. #3 Re: Rear Brake Hose Oddity
    Pulled up Rockauto.com and went to your year as a NA car, I think in 04 GT meant no charger. The wagner pictures for the rear lines appear to have a bit of a lead off them and a bend as if to clear the brake as you mention. Take a look at the pictures they have and see if they match up for you.
  1. 5th brake hose "hard line" solution ~$6
    By alacran in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2015, 01:18 AM
  2. Steel brake hose "guide"
    By MBruneaux in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2010, 07:26 AM
  3. $660 rear brake job
    By vailskier3 in forum The Rant Forum
    Last Post: 01-31-2010, 06:38 PM
  4. Rear Brake upgrades?
    By TMC in forum Off Topic Discussion
    Last Post: 05-08-2009, 08:06 AM
  5. 5th brake hose -hard line solution ~$6
    By alacran in forum How To Write-Ups/Tech Tips
    Last Post: 10-02-2008, 08:18 PM
