Re: Front driver side wheel pissing brake fluid :(
Okay so I took that brake line out that was rusted and I gave it a good look over and it doesn't seem to be rusted all the way through but it was the one with the heaviest rust on it so could it still have been the problem? I'm thinking of just replacing all of the brake lines just to be sure.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
If you are up to it.. do them all and never worry again. Most of us do them one at a time, cause we be lazy.
As for knowing if it's the culprit. When you pumped the brakes and it oozed fluid, wasn't that right above where the fluid dripped? Taht's the line you want.
It seems like it was the one that was leaking because it was coming from that area. I'm hoping that my master cylinder is not leaking because it's in the same general direction only right above that area. And that brake line didn't come out very easily it was a tight fit. Maybe my headers had something to do with that because the downpipe is bigger than the old one. Also how would I go about dropping the cradle a little bit because I feel like that would give me more clearance.
