Thread: Quick Question - Anti Pogo Washers
Results 1 to 8 of 8
  1. #1 Quick Question - Anti Pogo Washers
    Jun 2011
    ontario
    couple quick questions,
    10203412 is this the part number for all 4 and will they work on 04-08 GP's?
    can they be installed easily after I've already done new springs/struts etc?
    Thanks
  2. #2 Re: Quick Question - Anti Pogo Washers
    Nov 2012
    Madison
    Quote Originally Posted by poopoopeepee View Post
    Thanks
    Looks to be the right part #, I just got mine from the W-body store. They work for all GPs. You will be able to swap out the front easily. Lift the hood and twist off the nut and replace washer with Antipogo, twist nut on. The backs dunno. If you can keep the strut shaft from spinning you might be able to do rears easy enough.
  3. #3 Re: Quick Question - Anti Pogo Washers
    Got mine at the JY ... they are subframe washers.
    You can't typically install them after the fact. The strut has to have the top nut removed.
  4. #4 Re: Quick Question - Anti Pogo Washers
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    not to hard to do after the fact, the fronts are really easy and the rears just involve climbing in the trunk and a little tight space.
  5. #5 Re: Quick Question - Anti Pogo Washers
    Pennsylvania
    I saw them stupid cheap on ebay a while back.
  6. #6 Re: Quick Question - Anti Pogo Washers
    If you can get the backs off w/o the center rod of the strut spinning, kudos to you. I'll do them out of the car with air tools thanks..
  7. #7 Re: Quick Question - Anti Pogo Washers
    Jun 2011
    ontario
    arrgh, i've just confused myself. Im in ontario canada, just called a GM dealer here, and they say that there are 2 part numbers (fronts and rears).
    10203412 - fronts 13.00 each not for pair
    10203413 - rears ...21.00 each not for pair
    Does this seem right to you guys? I see some people just get them from a junkyard, so if thats the case, then i already have them and wont need to get new ones?
    Its monday and Im a little slow today....help.
  8. #8 Re: Quick Question - Anti Pogo Washers
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    There are 2 different sizes for the subframe... but when using them as anti-pogo washers, just use the 412's all the way around. Correct me if I am wrong. but I am pretty close to positive that is what you need.
  1. anti-pogo washers
    By des19 in forum General Grand Prix Discussion
    Last Post: 08-13-2012, 06:35 PM
  2. anti pogo washers?
    Last Post: 08-08-2012, 08:30 PM
  3. anti-pogo washers
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-13-2009, 07:08 PM
