Thread: Broken Coil Spring. Advice on removal
Results 1 to 16 of 16
  1. #1 Broken Coil Spring. Advice on removal
    Jun 2012
    St. Paul, Minnesota
    I need advice on the best way to remove the assembly when it has a broken spring.
    What I'm mainly worried about is what will happen when I lift the car and the pressure on the spring is lessened. Not to mention all of the movement and banging around I'm going to have to do to get it out. Is this one of those jobs where it's better left to the professionals?
    photo 2 | Flickr - Photo Sharing!
  2. #2 Re: Broken Coil Spring. Advice on removal
    There shouldn't be any problems. Buy two quick struts. That way you change the whole assembky
  3. #3 Re: Broken Coil Spring. Advice on removal
    Apr 2012
    Goderich, Ontario
    I had this same problem on my wife's GT. I just replaced the sping because the strut was still good. I got a used spring for $20 and a shop charged me $60 to compress and install the spring. Cheaper then 2 new quick struts, however quick struts look like an easy bolt in.
    -Paul Walker
  4. #4 Re: Broken Coil Spring. Advice on removal
    like everyone else said its not a safety problem at all, the spring is trapped in the strut. jack the car up, remove it.
  5. #5 Re: Broken Coil Spring. Advice on removal
    If you're just changing the spring go buy a spring compressor for $20
  6. #6 Re: Broken Coil Spring. Advice on removal
    Feb 2013
    Detroit, MI
    Instead of buying you can pay a deposit n rent it, then get your full deposit back.
  7. #7 Re: Broken Coil Spring. Advice on removal
    If you change that spring or do quicks. You need an alignment.
  8. #8 Re: Broken Coil Spring. Advice on removal
    This ^^^
  9. #9 Re: Broken Coil Spring. Advice on removal
    SWPA
    Quote Originally Posted by GrandPrix06GT View Post
    Spring compressors are good tools to have. What good is $20 going to do you when you can't get to the parts store to rent them?
  10. #10 Re: Broken Coil Spring. Advice on removal
    ^ money might be short
    04 Comp G.
  11. #11 Re: Broken Coil Spring. Advice on removal
    I'm gonna buy a new spring compressor soon hopefully. Instead of the 2 pieces one on each side of the spring I'm going to get the one that you put on there and use an impact and it compresses the spring evenly.
  12. #12 Re: Broken Coil Spring. Advice on removal
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    My question is: how do you know your strut is good and what criteria are you using to determine the dampening of your strut?
    Just because a strut is not leaking does not mean the strut is doing its job. Another thing to consider is the spring. Springs will fatigue over time. Not all springs retain the same spring rate from vehicle to vehicle. By replacing a single spring rather than replacing them as a set, you run the risk of changing the ride characteristics and handling by changing the spring rate, side to side, on a given axle.
  13. #13 Re: Broken Coil Spring. Advice on removal
    Apr 2012
    Goderich, Ontario
    It's a $2,000 stock GT that my wife drives from A to B. it doesn't have to be perfect it's just gotta work. I don't think we did too bad for $80
    -Paul Walker
  14. #14 Re: Broken Coil Spring. Advice on removal
    Jan 2012
    Abilene, KS
    monroe has a 120 dollar rebate on 4 quick struts through the end of april and at rock auto and it only cost me $304...just my 2 cents
  15. #15 Re: Broken Coil Spring. Advice on removal
    Jun 2012
    St. Paul, Minnesota
    I went ahead and bought the two full assemblies last night from AutoZone because I need my car come Monday morning.
    Well, off to the garage. If I run into any issues with removal or install today, I'll be back. I'm using the write up on here so I don't anticipate any major issues. Thanks to all who responded.
  16. #16 Re: Broken Coil Spring. Advice on removal
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Monroe Quick Struts are a Godsend...LOVE those things! I did the fronts on my wife's van last summer in about an hour...most of that spent on the top bolts because of the metal plate that extends over the engine bay on a Montana...stupid van...lol Hope things went well for you!
  1. Performed broken spring fix on HUD, still nothing?...
    By rizer in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2013, 04:59 PM
  2. Bent pushrod and broken valve spring?
    By brokenmercy in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-07-2011, 05:31 PM
  3. Loose Ignition Key, Broken Spring?
    By Stormwolf in forum Engine
    Last Post: 10-25-2010, 06:29 PM
  4. Coil spring boosters
    By WhiteGT in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 10:34 PM
  5. Broken Spring
    By pski920 in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2009, 10:53 PM
