Thread: New tires, alignment, camber bolts
Results 1 to 7 of 7
  1. #1 New tires, alignment, camber bolts
    SE Level Member andante147's Avatar
    Winfield, IL (DuPage)
    Hi, forum - '03 GTP, stock, 150K
    Bought new tires last week, and went for alignment.
    Here's the shop alignment printout
    They said some of the specs can't be aligned the normal way, and that cam bolts would be the solution. (apparently this is caused by slight sagging of the springs, which all makes sense from what I've read on this forum.
    They charge about $30 per wheel for just the bolts (parts) and about $35/wheel labor.... so about $300 to do four bolts.
    Questions -
    ** If they will use my parts, I can get the bolts on Rock Auto for much less. Can you tell me which bolts I'd need for front and rear? (Rock auto page below)
    ** Should I suggest my mechanic drill out the strut holes instead (if he will do it)?
    ** Rock also has a rebate on Monroe quick strut assemblies for about $70 each a.r. Would you advise just doing the struts at this mileage, thinking it might clear up the sag? If so, will I need a new alignment? Cost is a major factor, but I try to keep this car in 'A' condition. I've done struts on an old Escort before. How hard a job for an amateur of moderate skills?
    Thanks!
    2003 PONTIAC GRAND PRIX 3.8L V6 Supercharged : Suspension : Caster / Camber Cam Bolt Kit Price
    MEVOTECH Part # MK5330 {#K5330} Alignment Caster/Camber Kit
    Front; Allows For Additional Camber Adjustment
    Rear; Allows For Additional Camber Adjustment
    $8.50
    AUTO EXTRA / CHASSIS RITE Part # AXK5330 {#RK5330} Alignment Caster/Camber Kit
    $9.44
    MOOG Part # K5330 Problem Solver; Cam Bolt
    Rear Lower Strut Mount; Magna Cam/Bolt Kit - adjustment range from -1-1/4 to 1-1/4 deg.
    Front Lower Strut Mount; Magna Cam/Bolt Kit - adjustment range from -1-1/4 to 1-1/4 deg.
    $10.30
    MOOG Part # K90474 Cam Bolt
    Front Lower Strut Mount; adjustment range from -1 to 1 deg.
    Rear Lower Strut Mount; adjustment range from -1 to 1 deg.
    $10.37
    RAYBESTOS Part # 6161036 Professional Grade
    Front; 14mm Bolts; Single Offset; Minus 1-3/4 Degree To Plus 1-3/4 Degree
    Rear; 14mm Bolts; Single Offset; Minus 1-3/4 Degree To Plus 1-3/4 Degree
    $12.75
    ACDELCO Part # 45K18036 {#88914256} Kit Includes 1 Bolt
    CAM,Steering Knuckle Camber ADJ -; 14MM BOLTS, +/- 1-3/4 DEGREE; 4 DOORS; SINGLE OFFSET
    $13.41
    RAYBESTOS Part # 6161050 Professional Grade; Upper
    Rear; 14mm Bolts; Double Offset; Plus or Minus 2-1/2 Degree
    $13.67
  2. #2 Re: New tires, alignment, camber bolts
    1) all camber bolts are the same, there is only like 3 companies that make them.
    2) i prefer slotting the strut to camber bolts. improper camber bolt installation means your alignment will eventually slip and go out of whack.
    3) if you don't have the time and money for springs/struts/top hats (the whole shebang) then don't worry about it now.
  3. #3 Re: New tires, alignment, camber bolts
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Are the struts done and ready to be replaced anyway? If so, then get the quick struts and replace the old ones. VERY easy to do, and yes - you'll need an alignment after that is done, but shouldn't need the bolts if they're saying you only need them because of the sagging springs. I'm no expert, so I may be all wrong on this...if so, just tell me to STFU...I mostly wanted to say that the Quick Struts are a God send if you need to do that...
  4. #4 Re: New tires, alignment, camber bolts
    If all cam bolts are the same, can you explain the various options above on the rock auto site?
    Regaring letting it go for now, I'm a little concerned about uneven wear on the brand new tires
  5. #5 Re: New tires, alignment, camber bolts
    I don't notice big problems with the struts. I'm guessing I could go a lot longer with them. Probably notice with new ones. I think the car sits a little low, but I can't say for sure.your logic makes some sense though. If I would ultimately do struts I could do them now and skip the cam bolts costs, andjust be out the strut money.
  6. #6 Re: New tires, alignment, camber bolts
    Dec 2012
    Hawai'i
    The camber doesnt look too bad. Will it wear the tires out a little faster? Yes. But will it generally result in better handling/cornering? Yes. I'm a fan of replacing old suspension parts but if the struts feel fine and aren't bouncy, I'd spend the very little money on camber bolts and install them myself. Then have it aligned. I'm not familiar with slotting the hole on the strut. Honestly I'm surprised the springs would sag that much but guess the alignment proves it.
    2002 Impala- SSC, AGX, 18" charger R/t rims w/8mm spacers, Magnaflow cat, U-bend delete, flowmaster 80 series crossflow, z28 tips, HAI, debadged, 35% tint, smoked headlights, full sound system
  7. #7 Re: New tires, alignment, camber bolts
    Quote Originally Posted by barnettimpala View Post
    Yes, I'm not sure the springs are sagging much - the car has a fairly low stance...but given the small tolerances in alignment measurement, it wouldn't have to be much, would it?
    So... if I were to put the cam. bolts in myself, it's likely they would throw the alignment off quite a bit until I get the car to the shop. I'm assuming this would NOT be a dangerous amount off - am I correct there?
    And I have to sort through what directions I can find ... on the front of the car the cam bolt replaces the lower one, and if I read correctly, on the rear the bolt replaces the upper of the two? And when we're talking about upper and lower, we mean of the two bolts that are close to each other on the bracket that is down near the steering knuckle. (I guess I'm asking if upper means that, or is there another bolt near the top of the strut somewhere)
    And... don't mean to be dense!... I'm still not sure which of the Rock Auto bolts in the picture above I should get. They don't all appear to be the same visually nor in the Rock Auto descriptions.
    Thanks
  1. Replies: 22
    Last Post: 12-07-2012, 12:06 AM
  2. Do I need camber bolts ?
    By GTP in RTP in forum Brakes/Suspension/Chassis
    Last Post: 11-21-2012, 09:07 AM
  3. Are Camber Bolts Needed?
    By dhall9 in forum Brakes/Suspension/Chassis
    Last Post: 07-05-2009, 09:14 PM
  4. camber bolts
    By nemesis in forum General Tech Discussion
    Last Post: 02-29-2008, 05:10 PM
