Thread: comp g strut help!
Results 1 to 7 of 7
  1. #1 comp g strut help!
    Sep 2011
    Omaha
    Hey guys I'm clueless on the suspension stuff...in need of help!! Do they make a comp g drop drop in strut? Or what parts would I need? I know the obvious, strut body, springs and honestly that's where I'm stuck..probably getting from GM Parts Direct: Your direct source for Genuine GM Parts unless someone has a better idea for me. Its gonna go on a 04gtp non comp g.
    3.5 in" pulley, zzp dp, custom hai, colder plugs, red wires- red means fast, Tog headers, resonater Delete, custom dyno tuned and max out injectors...
  2. #2 Re: comp g strut help!
    There's no drop in option for the comp g struts. All you need is new struts and new mounts..the rest of the hardware can be reused. Unless your springs are in terrible condition (which I doubt) those can be reused as well.
    04 Comp G.
  3. #3 Re: comp g strut help!
    Nov 2012
    Madison
  4. #4 Re: comp g strut help!
    Sep 2011
    Omaha
    I thought you needed 03 lca's to run kyb?
  5. #5 Re: comp g strut help!
    Sep 2011
    Omaha
    So new strut body and mounts and its good? What all comes in a "drop in"?
  6. #6 Re: comp g strut help!
    Nov 2012
    Madison
    Quote Originally Posted by Akuch26 View Post
    and KYB GR-2/Excel-G Gas 339089 Suspension Strut Assembly : Amazon.com : Automotive this style is all good on an 04
    yeah just strut and front mounts, backs should be ok. A dropin like complete strut,spring and mount? Do you really want to step down on a comp g with a drop in. I guess its all about your budget.
  7. #7 Re: comp g strut help!
    Sep 2011
    Omaha
    Quote Originally Posted by spazzz View Post
    I'm running fe2's right now so really anything would better I'm guessing..of these two. I was just curious what comes in a dropin struts. I didn't know the kyb's were made for 04's. And the only reason I was all about the comp g ones was at gmpartdirect they are like 105 $
  1. 04 comp-g strut replacement
    By phat pat in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2012, 12:56 AM
  2. Comp G strut swap
    By Compg4me in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2012, 07:58 PM
  3. Comp G trans in a non Comp G
    By Explicit_Spade in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2011, 10:31 PM
  4. Monroe Quick Strut vs. KYB Strut Plus...definitive?
    By FRESCOLIO in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2009, 05:27 PM
