Thread: Front Brake Upgrade for 01 GTP with Stock 16" Wheels
Results 1 to 10 of 10
  1. #1 Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    SE Level Member mikes01gtp's Avatar
    Mar 2013
    Alachua, FL
    What is the biggest rotors that fit? And what donor car can I get them from? What is all the parts needed to make the conversion?
  2. #2 Re: Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    12" is the biggest you can fit. You need caliper, bracket, rotor, pads, and possibly banjo bolts and lines
  3. #3 Re: Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    04-08 GP single piston front I believe. Want mine? Newish full ceramic pads with 3k on them. Hardware. ..banjos and new copper washers as well
  4. #4 Re: Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    Sep 2012
    North Carolina
    Youll need rotors though
  5. #5 Re: Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    Midwest 3800 • How to install F-body brakes [ Guest ] this fits under stock 16 inch wheels.
    98 to 02 camaro, and fire birds front brake.
  6. #6 Re: Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    Sep 2012
    North Carolina
    Or those. I have the F-Body Camaro brakes on car.
  7. #7 Re: Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    Quote Originally Posted by jlgp2007nc View Post
    Those are smaller than the F body/impala/monte carlo rotors from the 00ish era.
    06+ impala pads calipers rotors would be nice.
    All you ACTUALLY need to swap to 12" rotors are the caliper brackets, rotors, and pads from a 00-05 impala with 12" rotors.
    The caliper brackets will swap out, that's how the GMPP kit came.
  8. #8 Re: Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    Sep 2012
    North Carolina
    I know that. Just trying to get ride of mine.
  9. #9 Re: Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    i took mine to the scrap yard and sold all 4 rotors, calipers, bolts, brackets, and another set of 4 rotors, got about 20 bucks or so for it all.
  10. #10 Re: Front Brake Upgrade for 01 GTP with Stock 16" Wheels
    Sep 2012
    North Carolina
    I thought of doing that too but I figured I could help someone that needs a stock replacement or minor upgrade first. I keep them away from the elements but another month and ill probably trash them.
  1. F-Body front brake upgrade
    By jlgp2007nc in forum General Grand Prix Discussion
    Last Post: 03-26-2013, 09:26 PM
  2. crosslace wheels with 12 brake upgrade
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2010, 05:44 PM
  3. My 12" front brake upgrade. COMPLETE. Pics
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2010, 06:58 AM
  4. i need 12" brake upgrade help.
    By kirkkarem1212 in forum General Tech Discussion
    Last Post: 07-24-2010, 03:48 PM
  5. 12" front brake upgrade rim compatibility?
    Last Post: 05-06-2010, 08:22 PM
