Thread: "Hops" at certain speeds
Results 1 to 8 of 8
  1. #1 "Hops" at certain speeds
    Jan 2013
    Buffalo,NY
    Im looking for help with my 2001 GTP, 83K. Since about 50K, the car has been giving me a vibration that feels more like a wheel out of round. Its not always there, usually at about 25-30mph, worse when its cold out or even when the car is cold, or sometimes after turning. usually smooths out above 35mph. Comes back a little at 50mph. smooth again at 65mph.
    Every time I've had any work done I ask the shops to check for causes of this problem. They always tell me the front end is in good shape. tires have been replaced + balanced also-no change, also sway bar-no change either.
    Now I'm starting to wonder if I need struts or engine/tranny mounts.
    Thanks in advance for any help.
  2. #2 Re: "Hops" at certain speeds
    engine/transmission mounts and axles are usually the culprits for any vibrations that aren't wheel/tire related.
  3. #3 Re: "Hops" at certain speeds
    Jan 2009
    Tallahassee, FL
    Are you lowered at all?
    Otherwise I'd check out your mounts.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #4 Re: "Hops" at certain speeds
    I live here. DirtDog's Avatar
    Jun 2012
    Does the hop or vibration feel worse when u turn around turns certain ways? Or can u feel it while accelerating then not when u let off the gas? The more details about when u feel it the better
  5. #5 Re: "Hops" at certain speeds
    Jan 2013
    Buffalo,NY
    not lowered (no mods). It is sometimes worse after a right turn (when cold)and also seems to lessen under acceleration.
  6. #6 Re: "Hops" at certain speeds
    Jun 2012
    Quote Originally Posted by wezert View Post
    OK now it sounds more like a CV half shaft. I had to replace mine and they were like that. If u turn right and it happens then it would the left side CV half shaft that needs replacing. I would inspect that CV half shaft and see if the boot is broken or leaking grease
  7. #7 Re: "Hops" at certain speeds
    Jan 2013
    Buffalo,NY
    Thanks
  8. #8 Re: "Hops" at certain speeds
    Jun 2012
    No problem. Jack the car up and put it in neutral and spin front tires see if u hear anything. Also grab the wheel at the 12 and 6 o'clock and push and pull see if there any wiggle if so its a bearing. Then grab at the 3 and 9 oclock and wiggle it...if there's play a tie rod end is bad
  1. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  2. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
