Thread: BMR Sway bar bushing PN or supplier?
Results 1 to 3 of 3
  1. #1 BMR Sway bar bushing PN or supplier?
    Jan 2013
    Chicago
    Guys,
    Just picked up a BMR rear sway, measures close to 23mm, advertised 22mm.
    Where should i look to find the poly bushing? i looked on wbs, energysusp, and pfyc, as well as the usual vendor sites like zzp and intense, no one has 23mm or .905/.866" bushing size.
    Help...
    BUILT. Not Bought.
    00 GTP Daytona. 111k and counting
  2. #2 Re: BMR Sway bar bushing PN or supplier?
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Try Moog
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  3. #3 Re: BMR Sway bar bushing PN or supplier?
    Jan 2013
    Chicago
    did find that Oriellys has .8" bushings. If stock rear sways are 17mm the .8 bushing should be way too big since 22mm=.866"...anyone use these bushings before??? i doubt they are poly, so probably not worth it, but if theyre cheap and they fit i might use them for a bit until i find poly bushings.
    BUILT. Not Bought.
  1. looking for a reliable supplier of aftermarket parts
    By GTPAIELLO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2012, 08:41 PM
  2. rear sway bushing?
    By speed demon in forum Brakes/Suspension/Chassis
    Last Post: 08-25-2012, 07:35 PM
  3. Torque Converter Supplier Link
    By moddman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-20-2012, 07:22 PM
  4. Control Arm Bushing
    By VGPGT in forum Brakes/Suspension/Chassis
    Last Post: 06-11-2009, 03:56 PM
  5. Bushing
    By JCG's-GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-09-2009, 02:31 AM
