Hi Everyone,Im going change the front swaybar links on my 04 Grand Prix.Is it ok to just jack up and do one side at a time?Or does the complete front-end have to be off the ground. Thanks
I do both at the same time but I'm sure if you wanted you could do one at a time.
I think you'd just make it a lot harder on yourself if one wheel was on the ground and the other wasn't.
The second you take the sway bar off, the bar will pop up and the LCA will drop down.
Just jack the car up by the subframe.
with the long sway bar links 04 style you can easily do one wheel up at a time.
Yes I agree u can easily do one at a time. I had just one off today when I was replacing a CV shaft. No problem at all
One corner/one wheel at a time
Thanks for responding guys.
Seems the theory and the reality don't match up. +1 for the GM engineering team for picking soft sway bar bushings.
Thanks for the info
