I couldn't be more peed off right now. I replaced the whole strut assembly and control arms on my 2001 GP, also replaced the anti-sway bar since the ends were cracked. I'm trying to put everything back together and noticed the new anti-sway bar is slightly larger than the old one. Called Rockauto (purchased from them) and they NOW tell me that the 33mm probably won't work on my car if the original was 30mm... just now finding this out on Saturday night before Easter Sunday, I'm screwed. I called around most parts stores don't carry a 30mm, it's discontinued. Does anyone know if the 33mm will work? I dropped it in but there's very little clearance between the stabilizer bar and the steering arm. I try to lift the bar to get the bushing in place and it hits the steering arm. Maybe I need to place some weight on the wheel and let the frame down?? Not sure if that would help, seems like it will only raise it more and reduce what little space I have between bolt hole in the bar and the bolt hole in the control arm frame. HELP!!
