Related to previous thread, but since several guys have suggested doing the LCA's, here are some photos. Maybe I should just do both LCA's and subframe bushings. I don't want to take it apart twice if I can help it. (It's cold in Chicago right now!)
I tried supporting the car from the jack spots and then tried to jack up just the subframe to see if it would move, but I couldn't see it moving.
Also tried to wiggle the tires when the car was elevated. I would say there is an EXTREMELY small amount of movement. Should this be absolutely zero movement?
Bushings.jpg if these don't enlarge when you click on them I'll post them a different way.
Thanks
