what is the best way to make my car a low rider, i know i will have to pick up some springs and dampers but how much labor will it be and how much would it cost total?
Best way to make your car a low rider?
Sell it and go ruin some other car.
depends what you wanna do how extreme of drop your planning to go and if your gonna do other stuff while your at it. you can expect to spend somewhere between 500-1000 total probably it all depends what all you want and what you buy. You will atleast need springs, struts, strut mounts, and a camber kit. Depending how low you go you will need mount spacers as well or shortened dogbones. Most seem to have better luck with the spacers. Without one of these you will have alot of vibration. Without one of these your axle geometry is thrown off. You will probably also want to get a 4 corner alignment when your done after about a month. A month because thats about how long it takes for the springs to settle. Other things many also invest in when upgrading suspension include upgraded sway bars, strut tower braces, and tubular trailing arms. These all help to stiffen up your suspension.
