Thread: Mission for no more clunk
Results 21 to 40 of 51
  1. #21 Re: Mission for no more clunk
    SE Level Member Fountaine's Avatar
    Feb 2013
    home
    i cant see shelling out 500 bucks for those, sorry. as cool as they may look, thats a lot of money.
    Agreed. For a car that is pig nose heavy and could kill you with understeer.
    2006 Turbo 6 speed Grand Prix
    cam, heads,turbo, manual swap
    projector retro, coilovers
  2. #22 Re: Mission for no more clunk
    Never Never Land
    I kinda skimmed through the thread. I saw in one post Dave mentioned subframe bushings. That's prob your problem. I chased a clunk and replaced LCA's with new bushings and ball joints, struts, mounts, sway bar links, and motor/trans mounts...only thing left was subframe bushings but I never got to them.
  3. #23 Re: Mission for no more clunk
    Dec 2010
    DMV
    Well that answers my question lol. Easy to replace?
  4. #24 Re: Mission for no more clunk
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    Yeah im gonna go all out and tackle the whole suspension, so subframe bushings are on order. Im looking for a good how too but it looks straight forward enough. This thing is gonna have one smooth ride when im done!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  5. #25 Re: Mission for no more clunk
    Yeah it is amazing what a full suspension refresh will do for a car.
  6. #26 Re: Mission for no more clunk
    Marysville WA
    So parts are on order, what do you guys prefer Poly motor and trans mounts or solid trans mounts?
    I asked Vinnie when I ordered the spacers and he suggested it might be a good time to replace them since ill have access when doing the spacers.
  7. #27 Re: Mission for no more clunk
    Here is the ClubGP thread
    ClubGP Message Forum troubleshooting
  8. #28 Re: Mission for no more clunk
    Marysville WA
    Awesome thread Drunkie, they seem to be a good bunch over there at ClubGP, what I gather from that thread is the subframe bushings as you mentioned early on. Parts on there way, ill update with pics as best as I can as they come in.
    First on the list is LCAs, Trailing Arms, and the subframe bushings.
    Had my new ZZP cat back welded up last night to replace the band clamps and man I was jealous of that lift at the exhaust shop. I hung out under my car as long as the guy was working on it poking at suspension parts!
  9. #29 Re: Mission for no more clunk
    antioch ill
    I bought bmr trailings arms the other day im pretty sure they are the thickest but be careful with low offset wheels they will rub ive been told
  10. #30 Re: Mission for no more clunk
    Marysville WA
    Matt just want your opinion on the trailing arms, what was the reason you settled on BMR over other brands or did it matter to you? I dont think my GXPs have a low enough offset to be an issue?
  11. #31 Re: Mission for no more clunk
    Trailing arms are far enough in, they won't come close to the wheel.
    UMI trailing arms are the next biggest for $145 they are also the cheapest for tubular setup
  12. #32 Re: Mission for no more clunk
    Marysville WA
    Update I discovered the Clunk!
    I dont know what the part is called but im missing a bracket that secures the rear sway bar to the body of the car let me know if you guys know what part this is. And if this is something I could pick up at a parts store or if I had to order it thanks!
    alt view
  13. #33 Re: Mission for no more clunk
    see yeah...what you should have there is a bracket that holds the sway bar down LOL.
    Glad you figured out your clunk.
  14. #34 Re: Mission for no more clunk
    Get one from a yard.
    The dealer will want too much.
  15. #35 Re: Mission for no more clunk
    Marysville WA
    Yeah the part from Oreilys was off by a few millimeters and so have to get this resolved tomorrow, its weird though knowing exactly what it is and now visualize it. Learned a lot today for sure just poking around. New suspension should be going in tomorrow!
  16. #36 Re: Mission for no more clunk
    The underside of your car is very clean BTW.
  17. #37 Re: Mission for no more clunk
    Marysville WA
    Thanks drunkie
    Ran into an issue today. The bolt that secures the lower end of the trailing arm to the wheel assembly is to wide for ZZPs opening on the bushing. Is it safe to drill out that bushing and use the stock bolt?
  18. #38 Re: Mission for no more clunk
    Marysville WA
    The hole is just barely too small
  19. #39 Re: Mission for no more clunk
    Arizona
    You will be fine just don't over do it
    BTW grease the bolt with anti sieze or something similar
  20. #40 Re: Mission for no more clunk
    Marysville WA
    I ended up using a new bolt from Home Depot 5/8th x 4" fit really well but was threaded all the way will that be an issue? Also does some one have a link for the order of the ZZP front sway bar endlinks?
  1. kamikaze corolla picks black gtp on suicide mission
    By ibhuff in forum Visual/Body Modifications
    Last Post: 08-16-2012, 03:54 PM
  2. Pics from the FL GP meet and Cars on a Mission show
    By Sandman in forum Shows and Events
    Last Post: 12-03-2010, 02:16 AM
  3. Newbie Here With A Mission
    By 02Cat in forum Introductions/Noob Questions
    Last Post: 11-04-2010, 01:33 PM
  4. FL GRAND PRIX MEET/Cars on A mission Orlando FL June 12th 2010
    By Spartan GL in forum Shows and Events
    Last Post: 06-14-2010, 04:49 PM
