You could try it, but....The issue is the spring is a 2.5" diameter and your stock springs have something much larger so they may not perch or sit in there correctly and could cause issues.
Also, a trick some guys do when they make their own top mount is flip the piece they use upside down and weld that in on the top mount, you do this so it can give you 1" extra of strut travel which is worth it.
