Thread: Strut Tower Brace is it worth it?
Results 1 to 20 of 38
  1. #1 Strut Tower Brace is it worth it?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    im considering putting a zzp STB on the front struts of my 99 GTP but is it really worth it, will there be any noticeable improvement in handling at any speeds?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: Strut Tower Brace is it worth it?
    GTX Level Member blackflag's Avatar
    Virginia
    buy the really expensive one.
  3. #3 Re: Strut Tower Brace is it worth it?
  4. #4 Re: Strut Tower Brace is it worth it?
    Virginia
    In all seriousness, i had them on previous cars and I didnt think it was worth the money.
  5. #5 Re: Strut Tower Brace is it worth it?
    Pennsylvania
    STB's should really be the last suspension upgrade, not the first. The difference is pretty small, especially when the important stuff is all squishy and weak.
  6. #6 Re: Strut Tower Brace is it worth it?
    Oct 2011
    Michigan
    well i already have the GMPP front sway bar and i plan on doing the rear one soon just wondering if i should throw a STB on there as well
  7. #7 Re: Strut Tower Brace is it worth it?
    huge difference? no...
    A difference? yes...
  8. #8 Re: Strut Tower Brace is it worth it?
    Oct 2011
    Michigan
    right i dont expect it to be amazing just let me hit those corners a little harder on my drive home
  9. #9 Re: Strut Tower Brace is it worth it?
    Ohio
    yeah you will for sure feel a difference..not crazy huge but it will be known
  10. #10 Re: Strut Tower Brace is it worth it?
    Oct 2011
    Michigan
    now will i be able to put a rear one in if i have subs back there?
  11. #11 Re: Strut Tower Brace is it worth it?
    Ohio
    maybe
  12. #12 Re: Strut Tower Brace is it worth it?
    Out West
    Duh.
    Whine with your Cheese?
  13. #13 Re: Strut Tower Brace is it worth it?
    Donating User Odi's Avatar
    Chicago South Suburbs
    find yourself a bigger rear swaybar first and better trailing arms. thats the biggest difference.
    and you gotta figure out yourself if you can fit one, all depends on how big your sub box is.
  14. #14 Re: Strut Tower Brace is it worth it?
    Oct 2011
    Michigan
    sub box reaches all the way to the top of the trunk i guess i could slide them forward (away from the driver) but would rear trailing arms really make that much of a difference and the progressive rear sway bar is next
  15. #15 Re: Strut Tower Brace is it worth it?
    trailing arms make a huge difference. you can bend the stockers with your hands.
  16. #16 Re: Strut Tower Brace is it worth it?
    Out West
    or just remove them completely.
  17. #17 Re: Strut Tower Brace is it worth it?
    Oct 2011
    Michigan
    subs are awesome they add depth to your music i love having bose and 2 12'' subs it sounds so good
  18. #18 Re: Strut Tower Brace is it worth it?
    Out West
    Bose and Depth do not belong in the same sentence or paragraph.
    Strut tower braces are always worth it though.
  19. #19 Re: Strut Tower Brace is it worth it?
    Oct 2011
    Michigan
    as far as stock speakers go GM Bose are very good better then other companies bose of that era yes some Rockford's would sound amazing and make the bose sound like poop but they do there job for stockers
  20. #20 Re: Strut Tower Brace is it worth it?
    Out West
    mark levinson were pretty boss.
  1. WTB: Rear strut tower brace
    By Pontiac Man in forum Wanted To Buy - Parts
    Last Post: 02-19-2012, 12:44 PM
  2. Strut tower brace front and rear
    By SleeperGS in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2011, 02:16 PM
  3. Strut Tower Brace
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 06:38 PM
  4. Strut tower brace
    By bkaab in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2008, 11:15 PM
