Thread: Steering wheel shaking
Results 1 to 9 of 9
  1. #1 Steering wheel shaking
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    01 GP GT
    My steering wheel started shaking when I was about a couple hours into a 3 hour drive. I ended up just slowing down and driving the rest of the way but the shaking still was there even at low speed 35mph or so. It's not a vibration like unbalanced tires but where the wheel shakes back and forth in your hands. If you take your hands off while driving it moves about a good inch almost 2 inches from side to side.
    When I got home I assumed it was a front wheel bearing, tie rod end, or maybe the ball joint so I jacked it up to check but I can't find any play in them at all. SO now I'm stumped. The only other thing I could think of was the alignment but I didn't hit any big bumps or curbs recently and was driving 65 on the highway when it started doing it.
    What am I missing.
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: Steering wheel shaking
    you may have tossed a wheel weight. try rotating the tires fronts to the back. if the vibration moved its the wheels or a even a bad tire.
  3. #3 Re: Steering wheel shaking
    Jan 2012
    Indianapolis
    The tires aren't balanced so it always has a small amount of vibration but this is more than just a vibartion. The steering wheel actually jerks side to side very rapidly.
  4. #4 Re: Steering wheel shaking
    id still rotate them. its free and if your tires are old and worn they could be the issue.
  5. #5 Re: Steering wheel shaking
    Jan 2012
    Indianapolis
    Alright I'll go try that. See if it helps. It would be nice it that was the issue
  6. #6 Re: Steering wheel shaking
    Jan 2012
    Indianapolis
    So it still shakes after the tires are rotated front to back..... could it be work strut mounts?
  7. #7 Re: Steering wheel shaking
    could be a bad axle. does it seem to stop when your off the gas coasting?
  8. #8 Re: Steering wheel shaking
    Enfield, CT
    Could the rack be wandering?
  9. #9 Re: Steering wheel shaking
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Does it do it at low speed? I had this problem but a few belts broke on my tires. Inspect the tires good to make sure they arnt bad, I also had my dad drive my car at me from a distance at different speeds, how I determined which tire was bad watching the front end move. But you said you rotated the tires and it still did it tho.
    2012 F150 STX
    - Gonna be a race truck
  1. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  2. GP 2008 shaking steering wheel above certain Speed
    By ibra0078 in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2014, 11:49 AM
  3. Wanted: Steering wheel cover/Steering wheel - 2005 Grand Prix GXP
    By killuminati in forum Wanted To Buy - Parts
    Last Post: 02-02-2014, 03:22 PM
  4. Steering wheel shaking a little after tire rotation
    By Haulero in forum General Tech Discussion
    Last Post: 12-08-2009, 09:56 PM
  5. Steering Wheel with LED
    By jcl1 in forum Visual/Body Modifications
    Last Post: 10-25-2009, 10:35 AM
