Are these a direct bolt in? If so, what trim levels do I look for? Can they be used with 16in wheels?
I was told the 2000 caliper brackets from a impala work with the stock caliper. I was under the impression the newer style impala had dual piston calipers that were a bolt on also.
I have this mod, they are pretty awesome for the price.
Find a set of dual piston calipers from a 06+ W-body from ebay or a wrecking yard.
Buy 06+ rotors and brake pads. Install, you slightly bend the brake line to accomodate.
If you get drilled ebay rotors, make sure you get drilled only. I had drilled + slotted and I did not like the feedback. I changed to drilled only and they are much better.
Thought so. Thanks guys.
