Thread: 12" rear brake setup
Results 1 to 6 of 6
  1. #1 12" rear brake setup
    SE Level Member 505pike's Avatar
    Nov 2012
    New Mexico
    Hello all. I have an Oldsmobile Intrigue that already has the 12" front brake upgrade and I want the rears to match before I put my rims on. I do understand there is very little to be gained messing with the rear brakes, I am doing it purely for looks. I have already ordered some Baer drilled rotors from a 2008 Pontiac G.P GXP, but I am having a hard time finding calipers and brackets at a reasonable price. I have found them remanufactured for about $170.00 for a single, but have a few questions.
    1. Does anyone know if my old brake calipers will be accepted as a core since they aren't the same type of caliper I will be buying.
    2. Anyone who has done this swap on the rear where did you find your calipers, did they include brackets?
    I read through the "Big Bad Brake" thread but did not find the answers I'm looking for. Thanks for any help!
  2. #2 Re: 12" rear brake setup
    GTP Level Member AjL227's Avatar
    IL
    1. You have to ask whomever you're purchasing from this.
    2. I have GXP brakes F&R, they definitely are worth it for looks alone. I got all my braking components from ZZP, so I can't really help for "on the cheap", but why don't you check out some local junkyards?
    A lot of GM big brakes are interchangeable between many models including Cadillacs to Corvettes.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  3. #3 Re: 12" rear brake setup
    Nov 2012
    New Mexico
    Thanks for the response, I was going to plan a u-pull visit this weekend in search, only problem is the only campatible 12" rear brake swap that I know of comes from the 2005-08 GXP, which my local u-pull says they have none. May just have to spend the $$.
  4. #4 Re: 12" rear brake setup
    GTP Level Member buickman104's Avatar
    NYC
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: 12" rear brake setup
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by 505pike View Post
    Most of them are gone now and a lot of junkyards miss label them.
    I called about 50 yards to find the ones for the Buick. You can find the calipers all day long new on the internet but you will have to pay a core charge and unless you got money to blow. It's really not worth it.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  6. #6 Re: 12" rear brake setup
    Nov 2012
    New Mexico
    Either way I can get everything I need to $100-150 cheaper than what vendors are asking, and although pricey, I think the rear brakes look terrible after swaping for 12" in the front and I have stock 16" Intrigue rims on, can only imagine with 18"s.
  1. Anybody know anything about the ZZP 13" brake setup?
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2010, 12:10 AM
  2. What brake setup should I buy?
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 11-21-2009, 01:20 PM
