Thread: 98 GTP - Turn wheel and brake, makes vibration in pedal and noise
Results 1 to 4 of 4
  1. #1 98 GTP - Turn wheel and brake, makes vibration in pedal and noise
    Jan 2012
    Boise ID
    Just like the title says. I push on the pedal in a slow turn and sometimes I get an antilock brake pulse type feedback in the brake pedal. Thoughts?
  2. #2 Re: 98 GTP - Turn wheel and brake, makes vibration in pedal and noise
    check your brake pads. it may be time for new brakes, if its already not to late.
  3. #3 Re: 98 GTP - Turn wheel and brake, makes vibration in pedal and noise
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    i would say u have a wheel bearing going out or a abs harness that has a short in it mine did that when the abs harness had a break in the wire or a small break not always open
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  4. #4 Re: 98 GTP - Turn wheel and brake, makes vibration in pedal and noise
    Jan 2012
    Boise ID
    Sounds good. I will check the pads, then move on from there to the wiring. The bearings probably need replaced. Is there a good DIY for the bearings?
  1. Brief grinding noise, felt in brake pedal/abs/trac light
    By KZOO3800 in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2013, 02:08 AM
  2. Help Shaking when accelerating and makes a squeaking noise.
    By Isidro Luna in forum Brakes/Suspension/Chassis
    Last Post: 07-22-2012, 03:09 AM
  3. Car makes humming noise when driving
    By usranger13 in forum General Tech Discussion
    Last Post: 07-15-2012, 03:53 PM
  4. Car makes odd howling noise
    By SDGTP99 in forum General Tech Discussion
    Last Post: 07-20-2011, 01:50 PM
  5. Replies: 15
    Last Post: 12-28-2010, 11:19 PM
