Been fighting an ABS light on my 2000 GT. Thought I'd fix it by replacing the pass. front hub as it was loose. New Timkin in and still have the ABS light. Had it scanned and came back as C00050, which states that there is no communication w/ the right rear hub. Checked the wiring harness to it and it's clean and wires look good (no broken or chaffed wires that I can see). Shop said it was either a wiring issue or the EBCM itself. I have a hard time thinking it's the EBCM as the light used to go out and come on when it felt like it, then finally stayed on. There's no play in the rear hub. I have metered out all the hubs w/ millivolts setting and when I am on the other 3 wheels I get a voltage reading when I spin the wheels by hand. I get on the right rear and my meter reads -OL-, which I is Open Loop/Out of Range. I have not tested for voltage on the harness side yet.
This car has 276K on it and I have good reason to believe that these are the stock rear hubs. If they're not then they have at least 150K on them now.
I don't want to be throwing another $100 at it hoping that a new hub solves the issue, but that's what my gut is telling me it is. Anyone have any other opinions/things to check before I just replace it and hope for the best?
