Thread: gxp struts on a 04 gtp?
Results 1 to 5 of 5
  1. #1 gxp struts on a 04 gtp?
    Sep 2011
    Omaha
    I'm putting some rebuilt gxp struts on my Gtp, I wad just wondering if there is much I would need to change? If so what is it?
    Thanks, AJ
    3.5 in" pulley, zzp dp, custom hai, colder plugs, red wires- red means fast, Tog headers, resonater Delete, custom dyno tuned and max out injectors...
    Nothing they bolt up just like the stock. It will raise the height up a bit though.
    04 Comp G.
  3. #3 Re: gxp struts on a 04 gtp?
    Sep 2011
    Omaha
    Oh really? I thought for some reason you might have to change the hub/knuckle Er something.
  4. #4 Re: gxp struts on a 04 gtp?
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    If I recall correctly, the LCA needs to be changed or something..
    Or maybe that's 2006. I don't know.
    But do it, they ride amazingly.
  5. #5 Re: gxp struts on a 04 gtp?
    I believe thats if you want to run that style sway link.
    I too forget what years they had the sway bar go from the strut to the bar, instead of the LCA to sway bar.
    I thought it was 04-05 and in 06 they switched back to the 97-03 style.
  1. fe4 gxp struts
    By Akuch26 in forum Brakes/Suspension/Chassis
    Last Post: 08-23-2012, 06:14 PM
  2. Struts, or struts and springs?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-14-2012, 07:23 AM
  3. new struts?
    By des19 in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2012, 03:50 PM
  4. struts
    By rharper33 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 12:17 AM
  5. New Struts
    By Bigbm80 in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2009, 11:55 PM
