Drove the car home from mechanic the other day. He had to pull the passenger axle to get at the oil adapter. I took the wheel off on the drivers side and rotated the axle and the screeching was very loud with just a little turn. I noticed the very base of the axle (part where you would pry on to get out of trans) was moving as well. Not sure if that is normal or not to turn but the screeching is brutal. Need some help.
