Thread: Strut bar
Results 1 to 19 of 19
  1. #1 Strut bar
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    Just pick up this strut bar for $18 of a supercharged regal. Is it any good for gtp. I think there's a bracket that is used to be bolted to the strut mount bolts. and could I use another of the samr in the rear?
    Sent from my SGH-T679 using Tapatalk 2
  2. #2 Re: Strut bar
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    that is a GMPP strut tower brace it came stock on certain Wbodies like regals and monte carlos, there doesnt appear to be a bracket on that one which means to put it on your GTP you need to drill into your strut towers, yes you can put one in the rear
    weather it helps or not is all a matter of opinion, i have a ZZP STB and i love it
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #3 Re: Strut bar
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Get ahold of Don at Home Page. He makes the brackets you need.
    GPONA #1 Cyber Bully
  4. #4 Re: Strut bar
    Florida
    Just drill 4 holes (2 per side) in the strut towers. Obviously you want to set the bar in place, center it, then make where to drill.
    Yes, you can put one in the back. Brackets make it way easier to install, but supposedly allow the bar to flex some.
    I put one in my 02 GTP, and would never take it out. It really did help the handling out.
    Jul 2012
    California
    Thanks for don romes page, couldnt find it earlier. So the front and rear stb are the same??
  6. #6 Re: Strut bar
    New York
    I purchased the GMPP sway bar kit at close out for $125 to replace my stock front sway bar that had cracked after 11 years at one of the end links. The kit includes a bigger front bar, a bigger rear bar, and the strut tower brace as shown above-no brackets-just drill 4 holes as others have suggested. I already have front and rear strut tower braces so I did not use mine but like others have stated above, strut tower braces absolutely effect the handling of the car and the stiffness of the chassis.
  7. #7 Re: Strut bar
    Regals and Impalas don't need silly brackets. Drill and bolt. You'll smile for years.
  8. #8 Re: Strut bar
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I am looking for some stb's, where you find yours? wreckers?
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  9. #9 Re: Strut bar
    Yup.. $10 usually.
  10. #10 Re: Strut bar
    St Thomas Ontario
    Thx Bill.
    Jul 2012
    California
    Can the strut bar be polished? To match a polished supercharger
  12. #12 Re: Strut bar
    Texas
    Quote Originally Posted by iRideGTP View Post
    Sent from my Penis using Tapatalk 2
    sure sand it and buff.
    85 Corvette
    01 TA
    03 Z06
    Jul 2012
    California
    Awesome. Bout to start working on that
  14. #14 Re: Strut bar
    See ya in a couple days when you give up.
    Jul 2012
    California
    Haha sounds like a challenge . Na I probably will give up if its too hard as ive never done it before and I dont even have the right tools but we'll see wat happens
    Jul 2012
    California
    ...Almost there
  17. #17 Re: Strut bar
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  18. #18 Re: Strut bar
    Florida
    Jeez, I couldn't imagine hand sanding that whole thing. I'd either get it blasted the coated, or take a couple different flapper wheels to it, then hand buff.
    Jul 2012
    California
    I need to sand it down with finer grit and buff. Im taking my time with it and looking good so far
  1. 04 strut help
    By Toms04compg in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2012, 06:55 PM
  2. Strut Job
    By brandonl2000 in forum Brakes/Suspension/Chassis
    Last Post: 12-24-2010, 12:57 AM
  3. Strut ?
    By TheOtherNick in forum Brakes/Suspension/Chassis
    Last Post: 11-02-2009, 09:21 PM
  4. Monroe Quick Strut vs. KYB Strut Plus...definitive?
    By FRESCOLIO in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2009, 05:27 PM
