Thread: E Brake Light comes on intermittently
Results 1 to 20 of 23
  1. #1 E Brake Light comes on intermittently
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    So just yesterday my 97s E Brake light came on while I was accelerating and then as soon as I applied the breaks the light would go off, once I get going again same thing repeat repeat repeat. Tried scanning it this morning but of coarse no codes came up?
    Brakes are working great I just serviced them about a thousand miles ago, new rotors, pads, front driver side caliper. Im assuming this is not very uncommon but it was tough searching for this one on the forum.
    Ideas?
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: E Brake Light comes on intermittently
    SWPA
    Check your brake fluid. Its probably low.
  3. #3 Re: E Brake Light comes on intermittently
    This ^^^
  4. #4 Re: E Brake Light comes on intermittently
    Marysville WA
    Nothin quite like feeling like a complete newb, just when I thought I had the hang of things.
    It wasnt super low nor was it on the max fill level ill take her out for a spin and let ya know the result.
  5. #5 Re: E Brake Light comes on intermittently
    SWPA
    No problem. We are all newbies at one time. I had the exact same issue many years ago and when my friend told me to check the fluid I felt like a fool, but I learned something new.
  6. #6 Re: E Brake Light comes on intermittently
    Marysville WA
    Heh well fool is what I am tonight my good sir! Ran it to the gym and back and no more light. Bleh. Oh well ill stick with it and get there to veteran status eventually!
  7. #7 Re: E Brake Light comes on intermittently
    Houston
    Well the reason you ask these kinds of questions is so this thread will be here for the next person that runs across this problem.
  8. #8 Re: E Brake Light comes on intermittently
    Marysville WA
    Heh yeah win!!! The search function is not that great on the site I end up combing through other random threads and getting way off track!
  9. #9 Re: E Brake Light comes on intermittently
    Marysville WA
    On a side note why is it that when this light came on these was no code associated to it? I mean I get why codes flash and trigger the SES but what triggers the brake light to come on with no code?
  10. #10 Re: E Brake Light comes on intermittently
    brake light and abs and trac light are seperate from the pcm stuff
    they dont set off the codes
  11. #11 Re: E Brake Light comes on intermittently
    Marysville WA
    But its still got some kind of sensor that trips the light? Or is it even simpler then that?
  12. #12 Re: E Brake Light comes on intermittently
    SWPA
    Its just a basic sensor in the resevoir. The BRAKE light has illuminated to show low brake fluid on vehicles since at least the late 60's before there ever was ECU's.
    Its basically like a low fuel light, except for your brake fluid.
  13. #13 Re: E Brake Light comes on intermittently
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    If it comes on again you might want to check for leaks as well. Mine would come on every month or two and I would fill it back up. Finally noticed a small leak in the back at the proportioning valve.
  14. #14 Re: E Brake Light comes on intermittently
    GTP Level Member
    Oct 2011
    Raleigh, NC
    If it is the light that comes on when the e brake is set then pull up on the pedal and see if it goes off. That will tell you it needs adjusting.
    1997 Red GTP 182000 miles stock
  15. #15 Re: E Brake Light comes on intermittently
    He already fixed it guy
  16. #16 Re: E Brake Light comes on intermittently
    GTP Level Member
    Oct 2011
    Raleigh, NC
    sorry i had a brain fart, maybe this will help someone else.
  17. #17 Re: E Brake Light comes on intermittently
    Marysville WA
    Thanks guys, shes running solid! Now if I can just get some freakin time to install my new system so i can move on to my next project! Strut Spring Combo or maybe even coilovers!
  18. #18 Re: E Brake Light comes on intermittently
    Marysville WA
    So is it possible for there to be a really slow leak in the caliper itself? my fluid level dropped again but its really slow, and I do notice a little bit of brake fluid in my wheel when I park it so I know where the leak it. Pulled the wheel off today and made sure the bleeder was tight as well as the connection from the brake line and they were. But I still see a little bit of fluid pool up in my wheel, its really little but I can notice it. Any thoughts?
  19. #19 Re: E Brake Light comes on intermittently
    SWPA
    One of the piston seals might be going bad.
  20. #20 Re: E Brake Light comes on intermittently
    Have you ever changed the caliper?
  1. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  2. LED third brake light mod
    By gouje0864 in forum Visual/Body Modifications
    Last Post: 02-10-2012, 06:48 AM
  3. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  4. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  5. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
