Thread: abs light on! wth
Results 1 to 10 of 10
  1. #1 abs light on! wth
    SE Level Member 2002grandprixgt's Avatar
    Jul 2012
    sioux city iowa
    I got a 02 grand prix gt replace both rear wheel bearings and brakes plues one caliper. when u step on the brake peddle the abs starts groning now not sure what else it could be. I just repace a power streering hose the parts store told theres two different hoses one for non power assist streering and for power assist. It started doing this right after i changed the hose could i have gotten the wrong hose??? also sounds like the abs is tryin to engage when startin to drive until the light comes on
  2. #2 Re: abs light on! wth
    Grand Rapids, MI
    First, which hose did you get? And do you have Magnasteer power assist or not?
    And if it's just a small noise for a second only 1 time right after you start a drive, that is normal, that is the test cycle.
    Here is my thread on the ABS problem; it's centered more on EBCM failure but you might find a good bit of it helpful.
  3. #3 Re: abs light on! wth
    Jul 2012
    sioux city iowa
    the noise goes for about a block than the abs light came on and i think i got the non power assist it looked a little different
  4. #4 Re: abs light on! wth
    Grand Rapids, MI
    Okay, if you look in your trunk, there's white sticker under the lid in there with many 3 character codes. One of those codes tell whether or not you have Magnasteer.
    Find that, I'm going to look up the codes on GM service manual right quick.
  5. #5 Re: abs light on! wth
    Jul 2012
    sioux city iowa
    thanks
  6. #6 Re: abs light on! wth
    Grand Rapids, MI
    The Service Parts Identification Label under your deck lid will read NV7 for steering power, variable effort.
    This is what the label looks like:
    Look in #7
  7. #7 Re: abs light on! wth
    Jul 2012
    sioux city iowa
    is there a link or website i can find all those service numbers at?
  8. #8 Re: abs light on! wth
    Jul 2012
    sioux city iowa
    no nv7
  9. #9 Re: abs light on! wth
    Grand Rapids, MI
    This is the RPO Code List http://sm.gpona.com:9001/si/showDoc....=&cellId=47866
    You probably can't access it via that link, go to gpona.com and register there. use that same login info to get in gm service manuals (link is also on gpona)
  10. #10 Re: abs light on! wth
    Jul 2012
    sioux city iowa
    i belive thats my problem wrong hose
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  3. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  4. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
