Thread: Caliper Bolts wont budge
Results 1 to 18 of 18
  1. #1 Caliper Bolts wont budge
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Our caliper bolts dont have a locking mechanism do they? I have been at it for a while with the impact wrench and they wont move! Lil Blacky is all jacked up and wheels off and its taken me forever to get around to doing this job figures that the caliper bolts decide to stay put. Any input would be swell guys, havin a beer in the mean time!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Caliper Bolts wont budge
    nope.
    righty tighty, lefty loosey.
    hopefully you are going the right way lol.
    Maybe try a socket wrench on the bolt and grab a pipe for more leverage, or hit it with the impact and help it along by pulling.
    Just gotta be careful and not screw somthing up.
  3. #3 Re: Caliper Bolts wont budge
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    hit it with some heat. I've always done that and it never hurt a thing. One bolt I had to hit it with heat, a breaker bar, and a pipe just to turn it all the way out.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  4. #4 Re: Caliper Bolts wont budge
    Feb 2010
    TN
    Quote Originally Posted by BlackGT97 View Post
    That's what I did just be careful not to set the rubber boot over the pin on fire, that's what I did too
  5. #5 Re: Caliper Bolts wont budge
    Marysville WA
    Finally got it! Dam that thing was stuck on there I shudder to think how long its been since the last brake job! Paint is drying on the calipers and I should be putting everything back together soon. Had to impact it for like fifteen minutes on each bolt up front.
  6. #6 Re: Caliper Bolts wont budge
    Marysville WA
  7. #7 Re: Caliper Bolts wont budge
    Marysville WA
    What the heck is this?????? Its like a plastic/rubber sleeve on the caliper bolt, its only on one of them for the front calipers and I have no idea what is is since non of the others had it. I assume its important.
  8. #8 Re: Caliper Bolts wont budge
    you can buy a hardware kit, should come with sliders/bolts and the rubber ends, and new slide plates for the caliper bracket where the pads sit.
    grease tthem slider pin up good with synthetic brake grease, sometimes you get a packet with new pads.
  9. #9 Re: Caliper Bolts wont budge
    Marysville WA
    What if im reusing the caliper bolts and I just dont know which hole the guide pin goes into?
  10. #10 Re: Caliper Bolts wont budge
    see if a chunk is broke off inside the caliper, what ever side has some it, the broke one goes there lol. im not sure top or bottom.
    most of the time the rubber stays inside the caliper.
  11. #11 Re: Caliper Bolts wont budge
    Marysville WA
    Sweet! Hey so is it possible for a caliper piston to seize open? I have been trying to compress this caliper piston and ive tried everything all the other ones compressed nice and easily?
  12. #12 Re: Caliper Bolts wont budge
    make sure its not being pressed back in on a angle. if its square and straight, its seized. some times you cant really crank on it with a C clamp and the old pad over the piston, and crank it tight it may pop and slide back.
    good time to buy a whole new caliper and bracket. come as one piece, all new hardware as well. you just re use your brake line.
  13. #13 Re: Caliper Bolts wont budge
    Marysville WA
    Yup thats what im gonna do, bummed though the parts store closed like twenty minutes ago and I was so close!! oh well might as well get a new caliper, but all said and done I might as well have to the GXP conversion!
  14. #14 Re: Caliper Bolts wont budge
    Quote Originally Posted by h0wl0ngcanitbe View Post
    im loving my f bodys. i stop on a dime and give back change.....
  15. #15 Re: Caliper Bolts wont budge
    Marysville WA
    Yeah F Bodys would be a good choice too, but this was just supposed to be a simple break job that ended being a whole lot more!
  16. #16 Re: Caliper Bolts wont budge
    used cars. what ya gonna do. if it aint one thing its another.
  17. #17 Re: Caliper Bolts wont budge
    Marysville WA
    You said it, I just love these cars to much. But days like these make me wanna just go eff it an buy something new and boring!
  18. #18 Re: Caliper Bolts wont budge
    new always = a warranty too. i used dealer warrantys for the last 12 years on my last 2 trucks. and i used them good. the 03 had the front hubs changed 4 times,the whole front end 2 times, the trans the t case, and the rear end and locker all rebuilt or replaced with 40 miles left on the warranty. got ya's good..
  1. Please help Caliper mounting bolts
    By Cody Coy Ote Wesley in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2012, 03:48 PM
  2. tie rod end wont budge
    By WOTFTW in forum Brakes/Suspension/Chassis
    Last Post: 03-29-2012, 06:05 PM
  3. caliper silde bolts drying out
    By asite57 in forum General Tech Discussion
    Last Post: 02-09-2012, 08:42 PM
  4. sc pulley wont budge
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2011, 09:09 AM
  5. Stuck Caliper bolts
    By tjwenger in forum Brakes/Suspension/Chassis
    Last Post: 08-17-2010, 08:24 PM
