Thread: low speed clunking and creaking when turning....
Results 1 to 4 of 4
  1. #1 low speed clunking and creaking when turning....
    SE Level Member twillroth's Avatar
    MN
    I know there's other threads on this topic, so I'm not gonna try and ask what could be causing it. I know it could be the ball joints, strut mounts, struts, outer tie rod ends, or...etc., etc. My '02 GT has 204,000 miles on it, so I'm just gonna rebuild the entire front suspension.
    My question is: I wanna replace my strut mounts also, so when ordering quick struts like the Monroe, KYB, or Leacree's, do I just order any strut mount kit and call it good? It looks like some kits, from different brands, come with different components.
    What exactly do I need to order to change my struts and strut mounts when using a quick-strut set up?
    Thanks.
    Sent from my DROIDX using Tapatalk 2
  2. #2 Re: low speed clunking and creaking when turning....
    Apr 2009
    Fort Worth TX
    I think quick strut comes assembled with everything including mount and strut bearing????
    You mat just need tools and some know-how.
  3. #3 Re: low speed clunking and creaking when turning....
    Donating User Odi's Avatar
    Chicago South Suburbs
    quick struts are fully assembled, take off old ones and throw in new ones. kyb quick struts ride a bit firmer and have the stock height vs monroe that raise the car a lil bit but ride softer.
    with that many miles, id do the rear struts as well.
    MN
    Thanks guys!
    I plan on changing the rears, also, but first things first.
    Probably go with the softer ride. I put about 30k/year on it, so the better the ride, the better I feel...
  1. No more clunking, creaking or rattle in the steering colum
    By mbeeman350 in forum General Tech Discussion
    Last Post: 12-17-2011, 08:26 PM
  2. creaking/clicking
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2011, 08:40 PM
  3. creaking.
    Last Post: 07-02-2010, 12:25 PM
  4. Creaking noise
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 11:42 PM
  5. Dashboard creaking
    By kharma1 in forum General Tech Discussion
    Last Post: 01-05-2010, 07:53 PM
