Thread: swaybar install
Results 1 to 2 of 2
  1. #1 swaybar install
    palatine
    So for starters i have a 2000 gtp, I bought the upgraded 34mm sway bar, and was wondering if i really need to take off the tie rods to get this in, any advice would help thanks!
  2. #2 Re: swaybar install
    i popped mine off, take the nut off and hit the knuckle with a hammer, it will pop off, after your done just put it back and make it good and tight.
    dropping the back of the sub frame a few inches also helps to get them bolts out of the bushing brackets.
  1. Swaybar Sizes
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2024, 05:51 AM
  2. Dorman vs. GMPP swaybar?
    By Mjcanton in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2011, 10:50 PM
  3. Swaybar Brackets...
    Last Post: 11-13-2009, 01:07 PM
  4. Busted Front Swaybar
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:33 AM
