Thread: F body brakes..
Results 1 to 20 of 32
  1. #1 F body brakes..
    GT Level Member Erics00LS's Avatar
    Lindenhurst, IL
    Have searched and searched. Haven't come up with any real answers..just leaves me feeling confused.
    I have a 2000 Impala. From what I have heard, I have 12" rotors up front.
    It should be a straight up bolt on for F-body calipers, right? I have an opportunity to get some on the cheap.
    What all do I need to make it work on my car?
    '03 Buick Park Avenue Ultra - a few bolt ons
    http://www.facebook.com/groups/greatlakesareacarenthusiasts
  2. #2 Re: F body brakes..
    Portland Oregon
    F-body calipers and brackets. Either tap the brackets for the W-body bolts with a 14x2 tap or get the right size sleeves for the F-body bracket bolts. You'll also need to either bend your brake line to wheel well brackets down a little or get longer stainless braided lines. You'll also need to use the F-body caliper banjo bolts. All this info should be in the big bad brake thread
  3. #3 Re: F body brakes..
    Moved your thread out of "off topic" and into the brake/suspension area. Here's that brake thread the OH4 talks about.
    http://www.grandprixforums.net/big-b...ead-39174.html
    In the moderate braking/improvement section you'll find the F bodies.
  4. #4 Re: F body brakes..
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Only SS impala and Monte's have the 12 rotors
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
    Lindenhurst, IL
    Uh...my setup was identical to what was on my brothers supercharged monte carlo, lol
    Sent from my SPH-D700 using Tapatalk 2
  6. #6 Re: F body brakes..
    Houston/Baton Rouge
    Quote Originally Posted by Erics00LS View Post
    True, after looking through my notes. Its been a while.
  7. #7 Re: F body brakes..
    SE Level Member 99FormulaM6r's Avatar
    May 2012
    Just curious, after coming from a lot of time spent at LS1tech, where the common upgrade for F-bodies is the C5 brake setup (same calipers, minus the casting technique, but with larger rotors), why upgrade to F-body brakes when the C5 brakes are just a small step away? Too big for most wheels or is there another issue?
    AFAIK, the F-body brakes are still excellent, with good pads/fluid/rotors they'll still brake better than 99% of cars on the road.
    1999 Pontiac Firebird Formula M6: SLP lid, LS6 intake, GMMG catback, MGW, blanks/HPS/SS lines, Koni 4/4, Strano 35/22 sway bars, UMI PHB
    2001 Pontiac Grand Prix GT
    2007 Yamaha TW200
  8. #8 Re: F body brakes..
    Houston/Baton Rouge
    Quote Originally Posted by 99FormulaM6r View Post
    C5 caliper brackets wont work on our spindles. Thats why F-body guys mount C5/C6 calipers using custom brackets.
    KORE3 did design a bracket so we could use the C5 calipers and C5 13" rotors. A clubgp remember was working with them and has a set. He said they were going to put them in production after some testing, but haven't heard anything in a while.
    F-bodys are way better than stock GP calipers, but they are very weak and prone to clam shelling when over heated. C5s are better and C6s are even better in preventing this.
  9. #9 Re: F body brakes..
    May 2012
    Quote Originally Posted by Ridin ON Chrome View Post
    C5 calipers will mount right in the Fbody brackets, but then you don't gain the increase in rotor diameter.
    But yes, the C5's are pressure cast, rather than gravity cast, which does give them some more resistance to deforming under hard use. I wouldn't call the Fbody calipers "very weak" though, they seem to hold up quite well (compared to other factory calipers at least) under hard auto-x or track use.
    2007 Yamaha TW200
  10. #10 Re: F body brakes..
    Donating User Odi's Avatar
    Chicago South Suburbs
    c6 calipers work as well (just not the z06 ones) and are apparently even "stronger" from what i heard on vette forums. overkill for out rides, but swag for vette lettering.
  11. #11 Re: F body brakes..
    Rotors aren't that expensive, get the F-body rotors while your at it, since you will need new pads.
    And...If I'm not mistaken your rotors are actually 11.7"
  12. #12 Re: F body brakes..
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    isnt the impala a F-Body and should already have the brackets?
  13. #13 Re: F body brakes..
    May 2012
    Quote Originally Posted by bps02gtp View Post
    Camaros/Firebirds = F-bodies
    2007 Yamaha TW200
  14. #14 Re: F body brakes..
    Quote Originally Posted by Drunkie View Post
    Imp's come with F body rotors.
    Same part number.
    Lindenhurst, IL
    I thought the camaro's wheels were a different lug spacing? Or is it close enough that I literally can use camaro rotors? That's one of the main things that confuses me
  16. #16 Re: F body brakes..
    Topeka, KS
    Been using 2002 Camaro SS rotors for 4 years with no problems.
  17. #17 Re: F body brakes..
    They are: but look up the rotor specs, the stud hole is oversized to accommodate both bolt patterns.
  18. #18 Re: F body brakes..
    Nov 2010
    Illinois
    ok so if the impalas come with f body rotors then all i would need to do is grab the brackets and put it on my gp and it should work with my calipers right?
    Buffalo
    Or just grab the impala setup. 06+ is dual piston / 12" rotor setup. Plus it's a direct swap. No need to drill, tap, anything
  20. #20 Re: F body brakes..
    Houston/Baton Rouge
    You must not hang out on ls1tech "THAT" much then.. lol..
    They junt the stock rotors if they want to auto X
    and yes I know C5 calipers will work in f-body brackets. I will be running some soon. But you cant use the C5 13" rotors.
  1. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  2. F-Body brakes are on.
    By Sudden in forum Brakes/Suspension/Chassis
    Last Post: 08-27-2010, 02:44 PM
  3. F-Body Brakes Help
    By joesforspeed in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2010, 04:54 PM
  4. f body brakes
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2009, 10:36 AM
