Thread: F-Body brake question
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 82
  1. #21
    Buffalo
    So I see those sleeves listed a few posts up.
    Do anyone have any pictures of needs to be used or done to the f body brackets?
    I hear drill tap sleeves etc..
  2. #22 Re: F-Body brake question
    the sleeves work just fine if you ask me. that's what im using.
  3. #23 Re: F-Body brake question
    Sep 2011
    MI
    04 + are not '12"' and are too small.
    Sorry bout that, thought I read that somwhere....
  4. #24 Re: F-Body brake question
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    whoops i read it but didnt look up lol but can some one explain what rotors i need?
    Buffalo
    Yeah I'm just looking to "see" what i need and what need to do.
    If not, I also found an 06 impala set
  6. #26 Re: F-Body brake question
    Oct 2011
    Michigan
    if you already have the calipers and the slides just get this ZZPerformance - FBody Caliper Install Kit #ZZ-FBCALKIT
  7. #27 Re: F-Body brake question
    Quote Originally Posted by asite57 View Post
    why on earth would you pay 50 dollars for 15 bucks worth of hardware?
    this is just the sleeves,
    Quickest and cheapest place to get them:
    McMaster-Carr
    mcmaster.com
    P/N:6679K16
    Qty: 4
    Price: $3.15 each
    the hardware store has the rest for no more than 30 cents a bolt. why waste all that money?
    Buffalo
    $50 + s/h? I'd rather find an alternative source for the bolts and washers. Again. I never had a set of fbodys in front of me to examine
  9. #29 Re: F-Body brake question
    Oct 2011
    Michigan
    it was just a suggestion lol but for real what rotors do i need ones off a MC it makes sense the fbody ones whould have a different bolt pattern
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  10. #30 Re: F-Body brake question
  11. #31 Re: F-Body brake question
    Donating User Odi's Avatar
    Chicago South Suburbs
    from what i heard 06 impala calipers + brackets just bolt in. am i rite?
  12. #32 Re: F-Body brake question
    Yes, but you need pads and rotors from that vehicle as well.
  13. #33 Re: F-Body brake question
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Too bad they are cast iron.
    In reference to 06+ Impala calipers.
  14. #34 Re: F-Body brake question
    Quote Originally Posted by mechguy View Post
    Thus no warping?
  15. #35 Re: F-Body brake question
    Oct 2011
    Michigan
    so you guys really seem to know what your talking about when it comes to the f body upgrade just let me know if i got this right
    this kit with there pads and rotors
    W Body Store 12 Inch Dual Piston Brake Kit
    and these brake lines extended
    Stainless Steel Brake Lines
    is all i need to do the upgrade on my car?
  16. #36 Re: F-Body brake question
    and the f body caliper brackets, the bolts, and the sleeves.
  17. #37 Re: F-Body brake question
    Oct 2011
    Michigan
    you get those things in the kit from the w body store
  18. #38 Re: F-Body brake question
    this is the set i picked up, the brackets are in the middle under the calipers.
  19. #39 Re: F-Body brake question
    Oct 2011
    Michigan
    whered you get thoses and how much did they set you back?
  20. #40 Re: F-Body brake question
    Dec 2010
    Canada
    Thus no warping?
    Unless time warping?
  1. body question guys
    By clevelandfan in forum Visual/Body Modifications
    Last Post: 04-30-2011, 11:12 PM
  2. Body Question
    By Kenny75k in forum Visual/Body Modifications
    Last Post: 11-24-2010, 10:37 PM
  3. body year question
    By PLAYTME in forum General Tech Discussion
    Last Post: 10-30-2010, 10:55 PM
  4. Break Question
    By nikkigpgt00 in forum Brakes/Suspension/Chassis
    Last Post: 03-19-2010, 01:48 AM
  5. disk break question
    By kjohnson in forum Visual/Body Modifications
    Last Post: 06-08-2009, 04:24 PM
