Thread: uneven braking
Results 1 to 6 of 6
  1. #1 uneven braking
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    What causes uneven braking when I brake hard (not ABS hard) my car pulls hard right and left what causes this?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: uneven braking
    Did you try bleeding the brakes and inspecting the pads
  3. #3 Re: uneven braking
    if you have 2 different front tires this can happen, as well as worn front end parts. or bad alignment.
    brakes and wheel bearings should also be checked out.
  4. #4 Re: uneven braking
    HUDSON
    Dont forget that as the rubber lines age, the rubber hoses can get clogged and create a restriction and create a uneven pressure to the caliper and make the car "pull" to one side when braking.
  5. #5 Re: uneven braking
    good point, they can also swell up, or bulge aka bubble in the line, the pedal will hit the floor most of the time when this happens tho.
    its the whole left and right pulling that leads me to worn front end parts in my eyes. bad tie rods or ball joints.
    jack it up, do the good old push pull tests, see if the wheels are tight.
  6. #6 Re: uneven braking
    Oct 2011
    Michigan
    Well the alignment is off lol I didn't think that'll do it though
  1. Braking Issue
    By juggalette79 in forum Brakes/Suspension/Chassis
    Last Post: 04-24-2012, 08:49 PM
  2. Grinding when braking?
    By LuckyBambu in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2010, 11:54 AM
  3. lights dim when braking
    By hourang in forum General Tech Discussion
    Last Post: 01-05-2010, 01:51 PM
  4. odd braking issue, maybe ABS?
    By Pittman06 in forum General Tech Discussion
    Last Post: 11-05-2009, 02:52 PM
  5. braking problem
    By beastin1 in forum Brakes/Suspension/Chassis
    Last Post: 12-11-2008, 09:25 AM
