Thread: question about trailing arms
Results 1 to 14 of 14
  1. #1 question about trailing arms
    Aug 2011
    akron, oh
    99 grand prix 3.8 v6
    It has around 150,000 miles, and the rear shocks went bad and the drivers side trailing arm broke all at once. I had an alignment done about 2 minths before this happened.
    I replaced the shocks with brand new shocks , mounts pads and all but some ****ty looking trailing arm that was off a 2000 grand Prix. The arm had surface rust and was the stock U shaped design. After everything was put together we drove it around the block one time and the replacement arm is already bent!!!
    Do i just need a better trailing arm, or is something else probably wrong???
  2. #2 Re: question about trailing arms
    Charles City, IA
    Get dorman ones, they are tubular and dont bend as easy.
    SMGPFC Two Nipple General
  3. #3 Re: question about trailing arms
    GT Level Member jmoore4294's Avatar
    Quote Originally Posted by TheOtherNick View Post
    This if you're on a budget. But don't go running to wbodystore to get them. They can be had for about half the price on rock auto. And I'm sure you could find them cheaper than that elsewhere.
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  4. #4 Re: question about trailing arms
    UMI suspension sells a tubular with poly bushings.
    BMR sells some nice ones as well.
    But they're 130+ shipping.
    But they're hands down the best mod for the rear suspension you could make.
    If you wanted to go cheaper, dorman ones or the boxed ones that wbodystore sells.
    Similar results.
  5. #5 Re: question about trailing arms
    Aug 2011
    akron, oh
    so then its not something else worng w/ the frame or anything making it go bad??
  6. #6 Re: question about trailing arms
    No. Just a crappy design. And if they were used and rusting, that's just all the more reason to place the blame on bad trailing arms and nothing else.
  7. #7 Re: question about trailing arms
    moved to the correct section.
  8. #8 Re: question about trailing arms
    Ocala, FL
    I have UMI trailing arms on the back, and I have no complaints at all. I'd recommend them if you were looking to step up to something a bit better than stock, and want a little more than the Dormans.
  9. #9 Re: question about trailing arms
    Wichita
    U might take a look under your car & see if there isn't something bending your trailing arms causing them to break. Happened to me. I broke one lateral arm cean in half. Turned out my lateral arm was smaking against an out of place bolt. My car had been jacked up right behind the trailing arm, folding some metal & a bolt attatched to that metal, way out of place. So you might give that a check before you go through another trailing arm.
  10. #10 Re: question about trailing arms
    Get some umi ta's and call it a day. I love mine
  11. #11 Re: question about trailing arms
    Antioch, IL
    Rockauto.com
    dorman, they are 12-13$ each. I paid like 32$ shipped for a pair
    2009 Challenger SRT8
    Expert at being gay.
  12. #12 Re: question about trailing arms
    Aug 2011
    akron, oh
    Cool..im just getting some good ass trailing arms and tossing the stock crap. Thx for your help
  13. #13 Re: question about trailing arms
    Aug 2011
    akron, oh
    is the supercharged 3.8 alot faster than the reg?? and does any1 know what the hp is on the reg 3.8 v6?
  14. #14 Re: question about trailing arms
    Charles City, IA
    like 190 for na 240 for supercharged.
  1. Rear Trailing Arms
    By SlowNA06 in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2010, 09:18 PM
  2. Trailing Arms
    By shawngtp in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2010, 08:56 AM
  3. just an fyi--trailing arms
    By quinnp12 in forum Brakes/Suspension/Chassis
    Last Post: 02-03-2010, 12:38 AM
