Thread: 05 gxp issue
Results 1 to 7 of 7
  1. #1 05 gxp issue
    GT Level Member nicks98gtp's Avatar
    michigan
    hi guys, im trying help a buddy figure out the issue on his 05 gxp, his abs, t/c lights were coming on a while back so we replaced his front passenger wheel hub (speed sensor wires broke) and the lights went out for a while. Now ~800 miles later he's getting lights again, he had it scanned and it showed a bad rear passenger hub, so he figured he should replace all four while hes doing it to avoid any future issues. Well today he had a shop replace all four hubs, right after he left the lights were off, but now hes getting on the DIC (service traction system, service abs system, service variable effort steering) and cant figure out why. Ive checked all the connections at the hubs and they seem fine. any help would be appreciated
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  2. #2 Re: 05 gxp issue
    Take it back to the shop and let them figure it out.
  3. #3 Re: 05 gxp issue
    michigan
    im trying to work on it only because hes leaving for new york for an internship wednesday and doesnt have much time. Or it would be back at the shop. thanks for the help...
    Mercer, Pa
    Some shops use the cheap bearings. Take it back and let them put better bearings on. If they don't come with at least 1 year warranty they are junk and will al fail within a year or so.
  5. #5 Re: 05 gxp issue
    So he is only getting the lights in the DIC, but no abs or t/c light in the dash?
  6. #6 Re: 05 gxp issue
    michigan
    getting the lights on the dash too. abs and t/c. is the "service variable effort sterring" tied in with these as well? never heard of such a thing
  7. #7 Re: 05 gxp issue
    michigan
    turned out to be a faulty rear hub
  1. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  2. ABS Issue, Please Help.
    By drewprix86 in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2010, 10:14 AM
  3. KR issue, need help
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2010, 12:40 AM
  4. ABS Issue
    By m1sterb0b in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2009, 04:42 PM
  5. RPM Issue
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-19-2009, 01:32 PM
