Thread: $700 later...
Results 1 to 8 of 8
  1. #1 $700 later...
    GTX Level Member nikkigpgt00's Avatar
    MI
    So my bouncing issue is fixed...$700 later. The bouncing was caused by bad front, lower bushings. THEN I had to have new brakes and rotors on the front, an air filter and an alignment. Now it drives smooth! It never fails when one thing is found there is more to go along with it. I still have to figure out why my engine light has been on for 2 years and I want to get the part to hopefully fix my fluctuating gas gauge. Always something!
    ORIGINAL POST
    I want to get an idea of what my problem may be...
    When I'm driving and hit any kind of bump my tires rub on the wheel well, especially in the rear. I have had struts replaced in both the front and rear within the past 1.5 years. I have the pregen wheels and tires. Could this be that my struts are bad again or the springs? I'm afraid of this issue wearing down my tires so I'm trying to get an idea of where to begin...
  2. #2 Re: Bouncing & Rubbing Wheels!
    springs aren't stiff enough to keep the car off the wheels. the wheels youre running also have a low offset so the potential for rubbing is increased just by that.
    options: replace stock springs that are probably old and saggy, replace springs with lower springs that have a higher spring rate, run a smaller sized tire, run a different wheel, or roll your fenders.
    only one of those options are cheap: roll your fenders.
  3. #3 Re: Bouncing & Rubbing Wheels!
    Donating User Odi's Avatar
    Chicago South Suburbs
    its yer springs. thats why you replace them with your struts if theyre worn, to save the trouble later.
  4. #4 Re: Bouncing & Rubbing Wheels!
    MI
    I'm gonna have the springs replaced just for safety measure. What's involved in rolling the fenders?
  5. #5 Re: Bouncing & Rubbing Wheels!
    i really should do a writeup on it. however, for the time being i would suggest searching the internet.
    do not follow others advise about baseball bats, phone books, etc. you have to ways to roll fenders: a hammer or a fender roller, but both involve a heat gun and patience.
  6. #6 Re: Bouncing & Rubbing Wheels!
    SWPA
    For the rubbing issue, I didn't see it asked, but what size tires are you running?
  7. #7 Re: $700 later...
    MI
    Not the wheels or the tired thank goodness, but my tires are 225/60R16. It was my bushings now that they are fixed no more rubbing!
  8. #8 Re: $700 later...
    SWPA
    Thats good news.
  1. rpms bouncing while driving between 2nd and 3rd
    By RyanL in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2012, 02:57 AM
  2. Exhaust is bouncing...HELP!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 07-12-2010, 02:55 PM
  3. Bouncing projectors
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-19-2010, 08:34 PM
  4. Fixing Headlights' Bouncing
    By vega in forum Visual/Body Modifications
    Last Post: 02-20-2010, 07:31 PM
  5. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
