Koniig,
I tried to upload few pics, but didn't get it. Try to figure it out later. anyway, nothing special. I probably can't say anything you haven't already heard.
To me, the c/o was significant $, and I'm happy w/ them, but everything has pros and cons. If you have a healthy budget, and want to mod your ride height, c/o might be good for you.
On top of $, another con is they are louder than typ mcphearson strut, c/o has no rubber or isolators. It's a different feel, I feel the road more.
Con, as mentioned above, matching valving of strut and spring (which I'm not getting into).
Pros, you should be able to get as low as you want, and what was important to me, you can adjust them without taking them apart. Another pro, you can get as stiff a ride as you want. But not with ZZP, order them from manufacturer, like Arraut (HTM), and he can get you springs as stiff as you want.
Con, I have no idea how you would select the spring right for you, or how you match the valving, just trial and error and more $.
All I can leave you with is: I'm happy with my c/o, but I didn't start off w/ a nice ride to compare it to; and even though I patronize ZZP, in this case I would steer you away from their limited selection and over-inflated shipping and recommend you go directly to Arraut (HTM) if you want to pursue this.
