Thread: Metal scraping sound from front wheel
Results 1 to 9 of 9
  1. #1 Metal scraping sound from front wheel
    Sep 2011
    Ontario, Canada
    Just figured I'd post this up in case anyone has a similar issue. I was hearing a cyclical clicking / metal squeaking noise coming from my driver side front wheel when the steering wheel was centered, or turned up to about 90 degrees clockwise. It would rarely happen when turning to the left.
    Took the wheel off today and looked into it a bit further. There's some sort of clip at the 6 o'clock position on the back of the hub that comes into contact with the rotor. One side of the clip was against the rotor while the other was floating. So I bent the rubing side away, and the sound is now gone.
    On the passenger side wheel, I noticed this clip is flush with the rotor, and doesn't make any noise. What is the purpose of this clip, and is it worth replacing/fixing?
  2. #2 Re: Metal scraping sound from front wheel
    Donating Users crock's Avatar
    Traverse City, Michigan
    So the clip is on the brake pad touching the rotor?
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  3. #3 Re: Metal scraping sound from front wheel
    Sep 2011
    Ontario, Canada
    Quote Originally Posted by crock View Post
    No, from what I recall it's coming off the hub and is contacting the rotor, not near the caliper at all. It's off the inner side of the rotor. Felt springy, at least the right side one did, when I lifted it off the rotor it defaulted back to pressing on the rotor.
  4. #4 Re: Metal scraping sound from front wheel
    Pictures would be much appreciated!
  5. #5 Re: Metal scraping sound from front wheel
    May 2008
    staten island,NY
    thats the clip thats attached to the speed sensor just bend it back away from the rotor. its thin metal just push it and its fine
  6. #6 Re: Metal scraping sound from front wheel
    Sep 2011
    Ontario, Canada
    Quote Originally Posted by QwikGT View Post
    As I mentioned above, it's certainly touching my right wheel, is it supposed to be floating or in contact?
  7. #7 Re: Metal scraping sound from front wheel
    BAM. Look at that. Didnt even need Pictures.
  8. #8 Re: Metal scraping sound from front wheel
    Sep 2011
    Ontario, Canada
    Best I can do for now, but this'll give you the general idea. Click the pic for a larger view.
    It's just past the LCA ball joint.
  9. #9 Re: Metal scraping sound from front wheel
    May 2008
    staten island,NY
    its floating, bend it away from the rotor
  1. metal on metal sound
    By Toms04compg in forum Brakes/Suspension/Chassis
    Last Post: 03-21-2012, 04:54 PM
  2. Front wheel squeeks when wheel is straight.
    By chevyy1212 in forum General Tech Discussion
    Last Post: 06-13-2011, 07:02 PM
  3. Loud Metal Clanking sound
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2010, 02:05 PM
  4. metal sound/foam
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 12:45 AM
  5. weird sound when i turn the wheel...
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2008, 01:33 AM
