Thread: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
Results 1 to 20 of 21
  1. #1 Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    Chicago
    I just finished replacing struts all the way around plus installed new tires. As it turns out I still have more work to do. One of my lower control arms in the front have a bad bushing plus both front hubs are bad. I also have play in one of my inner tie rods. I just got all the parts from Rock Auto. Damn, that place is great. I ordered yesterday using ground shipping and got them today.
    Anyway, I am going to install everything this weekend. What specialty tools do I need? I don't mind renting any tools if it helps make my life easier.
    Hubs
    - Will this work?
    Auto Zone Axle Flange Puller
    Inner tie rod
    - I am guessing I can remove the outer most boot clip with pliers and break the inner clamp off of the boot. During reassembly I can reuse the outer clip but use a zip tie on the inner part of the boot.
    - For the inner tie rod can I use the following?
    Autozone Inner Tie Rod Tool
    Lower control arms
    - What do I need to separate the ball joint? This?
    Auto Zone Ball joint separator
    I would appreciate any suggestions...
  2. #2 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    for the hubs. Just remove the axles nut and smack the axle end with a rubber mallet, or thread the nut on 2 turns and hit it with your hammer, that will break it away from the hub and allow the hub to come out. Then remove the 3 hub bolts and it'll come right out. No need for a puller
    And the ball joint can be popped out with a long pry bar.
  3. #3 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    Minnesota
    The inner tie rod tool is going to be the most useful, other than that you can just use basic tools for the most part.
  4. #4 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    On the tierod boots i used zipties to hold the inner one on. My ball joints just spun in the knuckle so i had to cut mine off.
  5. #5 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    when bill did my trans swap to get the ball joins off, he used like a 4 foot bar, laid it over the lca and slid it under the car, and then stood and bounced on it, i believe he smacked the side with a hammer but not sure.
    iirc you need a t 55 or t 55 .5 and a 21 or 22 mm wrench to get the 2 bolts off to remove the whole lca.
  6. #6 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    t 55 and 21 mm wrench
  7. #7 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    Chicago
    Thanks for the replies. I'll make sure I have a t55 as well. Any idea what size the axle nut is? I have a 36mm but it has a little play in it. I wonder if it is a 35mm. If so I will have to run out and get one.
  8. #8 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    Chicago
    Oh I forgot to add...
    I have a 1/2 impact gun. I know you do not want to use it when you put the new hubs in but is there any reason why I can't use it to remove the axle nut?
  9. #9 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    impact off is ok, you can use it to put the nut back on if you don't over do it.
  10. #10 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    I think its a 35mm, some are 32.
    Dont impact it on, Torque to 118 ft lbs.
  11. #11 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    Chicago
    I just realized something... I ordered Dorman control arms. I know it isn't Moog but I thought it was still a decent part. I started searching on the web about Dorman and the comments do not look that positive. Looking back though I do not think it was so smart as I put better quality parts on else where so far. KYB struts and mounts, Michelin MXV4 tires, Moog hubs, Moog inner and outer control arms, and Moog stabilizer links.
    Anyway, I have to follow through with the repair since I have everything apart but was wondering what folks had to say about Dorman LCAs. Are they going to hold up?
  12. #12 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    I have dorman lca no complaints here
  13. #13 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    X2 on the dormans, they work well, (they are stock replacements) took all the noise out of my front end after i changed them. nice and tight now too.
    and i got mine for 42 bucks a side, cant beat that much.
  14. #14 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    Chicago
    Cool. Thanks guys! I heading out to the garage to finish up. I started last night on the drivers side with disassembly. The hardest part of removing the hub was the damn 3 bolts. Even after breaking them free they were tough to turn and slow going. If I had my way I would love to have had a fresh set of bolts to put in. I hope they go in much better with the new hub.
    Oh I forgot to add, removing my rotors were a pain in the azz as they were frozen to the hubs. I have about 25% life remaining in them along with the pads. I don't know why they were so difficult to remove this time around as I have done my brakes in the front a few times already. I originally tried pounding on the inside of the with a wood block and a big hammer but they would not budge. After 20 minutes I had to resort to hitting them straight on with the big azz hammer. I was hitting the edge of the rotor where the pads do not contact but either way I was hoping to avoid doing that. I have cheap china rotors in the front and I swear those things really rust. When it was all said in done there was a pile of rusted metal probably big enough to fill one or more coffee cups. I am not kidding either. I did notice that the edges of the inner pad are wearing unevenly. I wonder if that is related to the play in the hubs that I am replacing or if I have another problem with calipers themselves. My guess it is due to the bad bearings that I had.
    Since I pretty much replaced everything in the front end it looks like I will need to do the brakes soon too. I am not sure if I will just get some cheap rotors again or if I will get some better rotors this time. I have also been wondering about upgrading to a bigger rotor such as a 12" setup. I don't know if that is cost effective or what the downsides would be if any. As soon as I finish replacing these parts today I will have to figure out which option I am going to do there. All I can say is that I replaced tons of crap on this car in the last year. Prior to that it have been bullet proof.
  15. #15 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    The 3 bolts come out hard because they have loctite on them from the factory. They will go in better than they came out.
  16. #16 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    Minnesota
    x2 on that. Those clip rings they give you with the inner tie rods suck. I had them fall off like 3 times before I said screw it and zip tied them. Only thing better would be if you could find a different style clamp the was thin enough.
  17. #17 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    Chicago
    Guys,
    I have everything done. Lower LCA's, both front hubs, new front rotors and brakes, outer tie rod end and stabilizer links replaced. I can't get the inner clamp on the driver's side inner control arm off. I can't believe I am stuck on that part after replacing everything else. I am spent at this point. I did not order a new boot and I am afraid to rip it. I am supposed to get the car aligned tomorrow morning too. I am stuck at this point unless I want to pony up the $200 the shop to replace one inner tie rod.
  18. #18 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    Cut the metal clamp off with sidecutters and rub some grease on the inside of the boot then slide it on and ziptie it.
  19. #19 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    dont they just have a crimped band on them? if so why not cut it with some snips or dykes.
  20. #20 Re: Replacing hubs, front LCA's and inner tie rods - Specialty tools?
    Chicago
    Okay, so I was able to pry the clamp off with a screwdriver wedged up against the stabilizer bar. It is very tight on the drivers side. Assuming the tool I rented fits the inner tie rod end getting it off should be easy now. However... I noticed that there is a lot of fluid in the boot. Is that normal for the mileage and usage or should the rack be bone dry? Otherwise do I have another problem brewing with a bad seal on the rack itself?
  1. How to replace front hubs
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 03-12-2015, 11:18 AM
  2. '00 Grand Prix Front Wheel Hubs
    By A70Runner in forum Brakes/Suspension/Chassis
    Last Post: 12-26-2011, 05:35 PM
  3. Replacing front hub/bearing
    By SnowDrift in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2011, 05:20 PM
  4. What tools for front brakes
    By KenH83 in forum General Tech Discussion
    Last Post: 07-01-2010, 08:27 PM
  5. Replacing Front Bearing/Hub
    By TMC in forum How To Write-Ups/Tech Tips
    Last Post: 01-13-2009, 01:13 AM
