Thread: i got no idea
Results 1 to 8 of 8
  1. #1 i got no idea
    GT Level Member Toms04compg's Avatar
    Michigan
    04 gtp i changed out front struts and mounts because the ride was rough and a loud noise like mounts would make. Well i still fot 100 percent of the noise . Its from 10 to 50 you hit a little bump you get a clud in the front im going broke with no ideas. Would motor mount do it ? I have flipped dog bones. Thanks
  2. #2 Re: i got no idea
    GTP Level Member
    Oct 2011
    Raleigh, NC
    sway bar ?
    get a solid one
    1997 Red GTP 182000 miles stock
  3. #3 Re: i got no idea
    checking motor mounts wouldnt be a bad idea
  4. #4 Re: i got no idea
    Michigan
    Five when checking the mounts what should i be looking for ? But yeah i looked at sway bar links and there connected.
  5. #5 Re: i got no idea
    Michigan
    Bump
  6. #6 Re: i got no idea
    GTP Level Member
    Pittsburgh
    its the Endlink. The part that goes from the sway bar to the strut, I had the same noise on my 04. Mood makes a improved one with Zirk fittings
    2003 SSEi,
  7. #7 Re: i got no idea
    could be the lca bushings and /or the ball joint. my front end was making noise as well over bumps, changed the lca's and no more noise.
    if you jack up the car and remove a front tire, look at the bushing for the lca, see if its torn or dry rotted.
    i paid 42 bucks a side for dorman lca's from partsgeek.
    and the sway bar, look from the under side of it where it hooks up to the end links, they crack underneath first it seems. new solid dorman sway bar and end links can be had for under a 100 with all new bushing and hardware.
  8. #8 Re: i got no idea
    Michigan
    Thanks guys ill take a look in a bit here.
  1. Good Idea or Bad Idea?
    By Robby Avery in forum Turbo
    Last Post: 01-25-2011, 04:55 PM
  2. I have no idea what is going on!!!!!
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2011, 05:12 AM
  3. i have know idea
    By TurosGTP in forum General Tech Discussion
    Last Post: 08-11-2010, 08:51 PM
  4. Good idea - Bad idea?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 04:51 PM
