I just finished replacing struts all the way around plus installed new tires. As it turns out I still have more work to do. One of my lower control arms in the front have a bad bushing plus both front hubs are bad. I also have play in one of my inner tie rods. I just got all the parts from Rock Auto. Damn, that place is great. I ordered yesterday using ground shipping and got them today.
Anyway, I am going to install everything this weekend. What specialty tools do I need? I don't mind renting any tools if it helps make my life easier.
Hubs
- Will this work?
Auto Zone Axle Flange Puller
Inner tie rod
- I am guessing I can remove the outer most boot clip with pliers and break the inner clamp off of the boot. During reassembly I can reuse the outer clip but use a zip tie on the inner part of the boot.
- For the inner tie rod can I use the following?
Autozone Inner Tie Rod Tool
Lower control arms
- What do I need to separate the ball joint? This?
Auto Zone Ball joint separator
I would appreciate any suggestions...
