Thread: Wheel Studs....
Results 1 to 15 of 15
  1. #1 Wheel Studs....
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    I'm not sure what the deal is but I'm wondering wtf is up with my GTP that I'm always breaking wheel studs. The car is close to stock, and I always use a torque wrench when tightening them. I think I've busted about 6 of them (the last one Discount Tire broke for me). It's not confined to one wheel as I've lost them on three of the four wheels on the car.
    Prior to this car I've never broke one, including one Mustang that made a whole lot more power than my GTP.
    confused in Vegas.
    (sorry if this is in the wrong section)
  2. #2 Re: Wheel Studs....
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Are you snugging them by hand before you're tightening them?
  3. #3 Re: Wheel Studs....
    Aug 2008
    vegas
    Quote Originally Posted by VinnieGTP View Post
    yes, get them all snugged down by hand ---- then tighten them a touch while still in the air, then torque them after loading the tire. Check the torque after dropping the car. No air tools when I'm doing it. And I'm certainly not doing anything differently than I've done in my previous 35 years of car ownership -- or the period of time I never broke a stud.
  4. #4 Re: Wheel Studs....
    Las Cruces, NM
    Thats really weird...our wheels are hub centric meaning they rest on the hub, not the studs. Studs just hold them on the hub, this shouldn't be happening. Maybe the lugs threads are just getting worn or weak and crossthreading when installing. I don't know.
  5. #5 Re: Wheel Studs....
    TDCRacing
    Guest
    my stud broke in half when i tightened it down with the stock lug wrench that comes with the car. Still havent fixed it
  6. #6 Re: Wheel Studs....
    Aug 2008
    vegas
    it is and why I thot I'd ask here. One time I looked down and there was one missing.... figured NBD. A few days later another was gone on the same wheel. This was on a 6 month old SKF hub. Then there's been the ones that broke while tightening (96' pounds, right?) ---- don't know. I checked out the one that Discount Tire paid to replace the other day and it's stripped and sitting in the hub sideways... so there's another one I've got to do.
    what bugs me is I'm real careful with stuff like this --- hand tight, torque wrench only, etc, and they're still breaking.
    thanks for the ideas tho.
  7. #7 Re: Wheel Studs....
    PA
    Yeah, you shouldn't have a problem with this. And I was going to ask how much you are tightening them to, but I see you said 96 ft-lbs. I do mine by hand, and don't check them everytime. I have heard 100 ft-lbs. Mine are usually 115-120 ft-lbs and I have never *knock on wood* broke a stud.
    2001 GSE
  8. #8 Re: Wheel Studs....
    Las Cruces, NM
    I'm even an impact guy because I don't believe 100 is enough for wheel studs. Have all your broke studs been aftermarket? Or did you put stock studs in the aftermarket hub?
  9. #9 Re: Wheel Studs....
    Aug 2008
    vegas
    Quote Originally Posted by Zef_66 View Post
    damn, I'd be scared to do that now. Oh well, it's the little stuff that can make one go hmmmm.
  10. #10 Re: Wheel Studs....
    Aug 2008
    vegas
    no, the AM hub, which went through three I think, were the ones SKF put in. I replaced the two then a third one broke. That's when I warrantied it since I was doing the axle anyway.
    the others have all been stock that broke and replaced with either whatever NAPA sells and Dorman. Heck, when I got the car I thot it was weird that there had been two replaced on the back.
    I've looked at the wheels closely, where the nut hits especially and they look fine to me, and the nut seems to sit in the recess evenly.
  11. #11 Re: Wheel Studs....
    Louisville, KY
    Are you using stock rims or 114.5 aftermarket?
    My Cardomain
  12. #12 Re: Wheel Studs....
    Aug 2008
    vegas
    stock chrome stars (non torque star).
  13. #13 Re: Wheel Studs....
    Jul 2008
    Poteau Oklahoma
    is the alignment corret? undue tension on the studs can come from a mis alignment.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  14. #14 Re: Wheel Studs....
    Aug 2008
    vegas
    just got a long overdue alignment a few weeks back --- the guy said it was pretty far off even though the wheel was straight and the tire wear was close to right. It was very 'twitchy' before the alignment.
  15. #15 Re: Wheel Studs....
    Jul 2008
    Poteau Oklahoma
    well then all I got left in my bag is fatigue or just plain bad metal.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  1. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
  2. Who is running ARP head studs???
    By Trannyman95 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 03:29 AM
  3. Studs
    By wrfdff4 in forum Tires & Wheels
    Last Post: 03-31-2008, 11:16 PM
  4. Wheel hub?
    By Mikel2k7 in forum Brakes/Suspension/Chassis
    Last Post: 03-02-2008, 09:22 PM
