Thread: Rattling front end
Results 1 to 8 of 8
  1. #1 Rattling front end
    Apr 2008
    Wheaton, il
    Anybody experience a noise from the front wheel area that sounds almost like a small loose hubcap would sound (if we had them) Lifted the car on jack-stands, grabbed, pulled and tapped on whatever I could nothing seems loose or broken Only hear the noise while driving and hitting a bump but not a hole. I can hear it at any speed and it doesn't matter if I'm going straight or making a turn. Car has 100k miles on it and I don't think any suspension work has been done, but everything looks good. Noise is a rattle rather than a snapping or cracking noise.
    Any ideas?
  2. #2 Re: Rattling front end
    Saraland Alabama
    a bad sway bar bushing, strut mount, or bushings can all do that
  3. #3 Re: Rattling front end
    Apr 2008
    Wheaton, il
    Any easy way to check strut mount or bushings without tearing everything out? Sway bar bushings are fine.
    Scott
  4. #4 Re: Rattling front end
    Saraland Alabama
    how do you know the end links are fine, they may look good, but the bolt may be turning (they corrode pretty quick) no great way to check strut mounts other than bounce test and look and listen (that's why I replace them every time I do struts)
  5. #5 Re: Rattling front end
    Jul 2008
    Fishkill, NY
    I know on my car the plastic engine splash shields are loose and ratting. The design sucks (as usual with things on this car). They use plastic capture screws at the top but are left free to flop around on the bottom. I'm gonna pick up some self tapping screws and screw them into the subframe to keep them from rattling.
  6. #6 Re: Rattling front end
    Apr 2008
    Wheaton, il
    Saw that too. In fact, the whole front bumper/grill assembly could move up and down an inch if you put any pressure on it. Replaced a bunch of the capture screws with bolts but the noise is still there. And yup, the splash shields and inner fender liners do move around quite a bit. Guess I'll just go piece by piece and refasten everything and see what happens.
  7. #7 Re: Rattling front end
    Apr 2008
    Wheaton, il
    Found the problem. Broken sway bar!
  8. #8 Re: Rattling front end
    Jul 2008
    Poteau Oklahoma
    at least you wont have a rattle, best side, now your car will handle a touch better when you get it fixed.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  1. front sway bar
    By Toasty in forum General Tech Discussion
    Last Post: 03-23-2013, 12:34 PM
  2. SD front air dam what do you know about them.
    By Dohner in forum Visual/Body Modifications
    Last Post: 03-10-2010, 05:28 PM
  3. 06 SE Front Air Dam/Rear
    By The_Avenger in forum Visual/Body Modifications
    Last Post: 05-12-2008, 06:54 PM
  4. GXP front end?
    By shotgundust in forum Visual/Body Modifications
    Last Post: 04-06-2008, 01:02 AM
